It is currently Thu Nov 20, 2025 2:23 am
PostPosted: Sun Sep 22, 2019 11:22 am
Car Model: 1983 Dodge D150
So at night I noticed my headlights, taillights and dash lights pulsate steady independently of engine rpm. It’s constant weather I’m driving 60 mph or sitting at an idle. Checked both my grounds on the battery as well as the ground on my electric fuel pump. Replaced my alternator, it was weak anyways, with no improvement. And battery tests strong. Any ideas? Thanks guys.
PostPosted: Sun Sep 22, 2019 2:46 pm
Faulty voltage regulation, either because of a failing regulator or an issue in the wiring between the ignition switch, the regulator, and the alternator.
Electric fuel pumps on carbureted vehicles are dangerous unless they're wired up thoughtfully. They're also usually unnecessary; why's this truck have one?
PostPosted: Sun Sep 22, 2019 2:52 pm
Previous owner installed one after the mechanical one went out. I was thinking it would be the voltage regulator. Any idea where it’s located? And why are electric pumps dangerous with carburetor vehicles? Should I go back to the mechanical pump?
PostPosted: Mon Sep 23, 2019 12:56 am
Correct fix would've been to replace the pump with another of the same type.
Firewall.
Read the link. On this board, red text within a message is clickable.
PostPosted: Mon Sep 23, 2019 4:48 am
Thanks! I’ll let you know what I find.
PostPosted: Mon Sep 23, 2019 9:02 am
if it is not the VR, check into what this article recommends
https://www.hotrod.com/articles/mopp-08 ... eadlights/
PostPosted: Thu Sep 26, 2019 5:25 pm
and additional info on resolving flickering head lights,,,
https://www.forabodiesonly.com/mopar/th ... ts.406392/
PostPosted: Fri Sep 27, 2019 3:54 am
Per your guys advice I got around to replacing that voltage regulator. Cleared it right up. Thanks again guys!
