It is currently Tue Nov 18, 2025 6:39 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Tue Nov 05, 2019 5:08 pm
https://www.forabodiesonly.com/mopar/at ... 714995843/
PostPosted: Tue Nov 05, 2019 5:09 pm
PostPosted: Tue Nov 05, 2019 5:21 pm
If look close in that picture,there is return spring on tranny kick down throttle rod. Is it there? Spring should hold rod against carb throttle full time. Rod and carb arm should move together full time no gap. That slot is fail safe only. If kick down rod gets stuck slot allows carb to return to curb idle.
PostPosted: Tue Nov 05, 2019 5:25 pm
https://www.forabodiesonly.com/mopar/th ... te.366635/
PostPosted: Sat Nov 09, 2019 11:46 pm
Car Model: 1975 Plymouth Duster
Funny you should mention that, but no. There isn't one currently on the car, nor has there ever been, and there wasn't even one on the parts aspen I bought. This would probably explain the funky kickdown behavior that seems to happen at random.
PostPosted: Sun Nov 10, 2019 4:36 pm
PostPosted: Sun Nov 10, 2019 4:37 pm
Black arrow where spring goes
PostPosted: Sun Nov 10, 2019 4:39 pm
Bottom Image
PostPosted: Sun Nov 10, 2019 4:44 pm
First two pictures, carb and trans rod both at cold fast idle.
PostPosted: Sun Nov 10, 2019 4:45 pm
Image Black arrow spring goes in that hole.
PostPosted: Sun Nov 10, 2019 4:53 pm
Rod look like this one?Image
PostPosted: Sun Nov 10, 2019 4:58 pm
That long slot is fail safe only
PostPosted: Sun Nov 10, 2019 4:59 pm
PostPosted: Sun Nov 10, 2019 5:17 pm
In this picture spring removed, carb has returned safely to curb idle, trans rod still at half throttle position. If trans rod were to get stuck for some reason,bind up, snow ice, internal failure etc, slot allows carb to return to curb idle. Fail safe.
Users browsing this forum: No registered users and 20 guests
