It is currently Tue Nov 18, 2025 8:50 am
 Post subject: Rear shift tab advice
PostPosted: Tue Dec 10, 2019 7:51 am
Car Model: 1962 Dodge Dart
Hi all,
I have received an order for a linkage and shift tab on my A833 transmission. However, the articulation point for the reverse (what is that called by the way?) only sits about 1/16th of an inch inside the slot in the shift tab. Is this correct? The rectangular portion of the articulation point is also a bit rounded. If I pull that part out could I add some material to the rounded edges and file everything back into shape (via welding)?
Paul
File comment: View of the rounded corners
File comment: View of the articulation point fully seated in the tab
PostPosted: Tue Dec 10, 2019 10:31 am
when you fit the tab on, and tighten it down it will pull the reverse pin up more flush with the tab.
PostPosted: Tue Dec 10, 2019 12:13 pm
Ah ha!
That's the kind of in depth knowledge I need! Thanks Greg, you saved me a lot of effort and headache.
Paul
