It is currently Mon Nov 17, 2025 6:05 am
Post new topic  Reply to topic  [ 101 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Fri Mar 27, 2020 4:55 pm
Image[/quote]
Is that a good place for the return spring to be mounted? Looks like engine torque would try to close the throttle on you.
jus sayin....
PostPosted: Fri Mar 27, 2020 7:05 pm
It is NOT a good place to mount it and it is not permanent. Good eye!
PostPosted: Sat Mar 28, 2020 8:40 am
I just thought the motor mount was torn and that was holding the engine in place! :D :D
PostPosted: Sat Mar 28, 2020 8:43 am
Poor man's Rev Limiter.......
PostPosted: Sat Mar 28, 2020 9:36 am
I can't believe you guys haven't already seen the combination throttle return spring/torque strap. It's been around. :mrgreen:
PostPosted: Sat Mar 28, 2020 10:32 am
I have been a little out of touch with the TRUE racers for a while now.
Keep all these tips and tricks coming.
PostPosted: Sat Mar 28, 2020 12:27 pm
I have abandoned experimental tech for the time being.
PostPosted: Sat Mar 28, 2020 1:29 pm
You went 'conventional'....
Is that allowed?
PostPosted: Sat Mar 28, 2020 2:36 pm
Is that allowed?
The fact that you are here says the same for you.
PostPosted: Sat Mar 28, 2020 4:17 pm
Point taken.
PostPosted: Sat Mar 28, 2020 9:42 pm
Online
Is that a good place for the return spring to be mounted? .
Mine has been mounted in a similar fashion for many years on the hyperpack dart... never had any problems.
PostPosted: Sun Mar 29, 2020 8:07 am
Really that set up didn't present any problems while driving and the reality of it is, throttle return springs are trying to close the throttle all the time.
PostPosted: Sun Mar 29, 2020 11:22 am
All the extra 'Bigfoot' adrenaline at WOT easily overcomes a little extra spring tension 8)
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Sun Mar 29, 2020 11:33 am
Joe knows :mrgreen:
PostPosted: Sat May 23, 2020 4:46 pm
Going up to Paradise tomorrow and see if the changes I've made help or hurt. Maybe I will run into Finnegan, but I doubt it. :D
