It is currently Tue Nov 18, 2025 8:50 am
Post new topic  Reply to topic  [ 1195 posts ]  Go to page Previous 14 5 6 7 880 Next
PostPosted: Thu Apr 30, 2020 11:43 am
I "found" 80 pounds under the gas pedal...
Haha.
Love it.
PostPosted: Thu Apr 30, 2020 5:34 pm
uh oh..
found another 40# behind the headlight switch..... toss..
:D :D
PostPosted: Thu Apr 30, 2020 6:39 pm
Got the steel mid plate cut out today.
Tomorrow I start notching the tube to move the engine back.
Not sure why Greg has so much weight hiding all around his car.
PostPosted: Fri May 01, 2020 2:06 am
Its in your car Stan!
Awesome project.
PostPosted: Fri May 01, 2020 6:16 pm
After I cut the chebbie mid plate out, notched the mid plate tube, it went together.
I still have a ton to do, but good clearance on the dampner, mid plate goes between the frame rails and engine sits good.
It was a good day.
PostPosted: Sat May 02, 2020 7:01 am
Online
Uber Cool!! 8)
PostPosted: Sat May 02, 2020 7:11 am
Dang that looks purdy. I have an individual runner induction system coming together too...
PostPosted: Sat May 02, 2020 8:45 am
Absolutely awesome Stan!!! :D :D Guess we should start a "Weber Gang" Can't wait to see it run!
So you are going with a liberty modified 833? Are you getting the gears face plated?
PostPosted: Sat May 02, 2020 7:40 pm
Rick, Weber gang sounds good to me, however I am on the long learning list for sure.
Liberty is putting steel reinforcements in my main case.
Can't spring for the faceplating yet, need to get it on the track first.
Still have some pricey parts to buy still.
Thanks for the reads and comments, long way to go...…...
PostPosted: Fri May 08, 2020 7:58 pm
Making the engine mount plate. Found a source for 6061 aluminum. Started making the template for the waterpump, timing cover and frame tabs.
PostPosted: Sat May 09, 2020 8:04 am
Looking good Stan!
It will be fun to see the colt do its thing!
PostPosted: Thu May 14, 2020 10:51 am
Template 3, I think this will work. I will see about some lightning holes after it's going together and everything is mounted.
PostPosted: Thu May 14, 2020 3:40 pm
That looks great Stan!
Question: Is there an electric water pump that works for the slant 6?
John
PostPosted: Thu May 14, 2020 5:02 pm
Bellhousing fitment.
PostPosted: Thu May 14, 2020 5:05 pm
John
John, always great to hear from you friend, I hope you all are doing well.
I don't know of one. Maybe I can talk Mark Goodman into making some for all the slant racers!
But he is a concrete man, so he doesn't need one.
I guess I will be running the old school dc motor and geared belt.
