It is currently Wed Nov 19, 2025 9:54 pm
 Post subject: PB adjusting rod.
PostPosted: Sat Jun 06, 2020 2:37 pm
Since I R and R the PB master cyl and finish with a complete brake job I've had this vacuum hiss down at the pedal. I was told that I need to adjust the rod. To do that do I have to remove the shroud thats bolted to the fire wall and under the dash. Its a mother to see everything and the humidity is about to kill me . lol Then the heat of the light doesn't help either.This is on a 1979 Volare.
 Post subject: Re: PB adjusting rod.
PostPosted: Sat Jun 06, 2020 4:01 pm
I used the search engine and found out its done by unbolting the MC. Do I just run the ball in . I grab the rod with vice grips and put a 3/8 on the ball but its not moving. Please help.
PostPosted: Sat Jun 06, 2020 4:12 pm
If you hear hissing it's highly likely the booster diaphragm is ruptured. Adjusting the pushrod-to-master cylinder clearance will not fix this.
PostPosted: Tue Jun 09, 2020 10:20 am
I rev up the engine and you can see the brake pedal move. I adjusted it some but it still has this issue. What the consensus???
PostPosted: Tue Jun 09, 2020 1:22 pm
I just bumped a thread on rebuilt boosters. There's a link in it with instructions for adjusting.
PostPosted: Sun Jul 19, 2020 7:53 pm
Mine is an aftermarket unit, but I can adjust the rod from under the dash, no need to remove the unit from the firewall.
https://tinyurl.com/yynpj4v2
