It is currently Mon Nov 17, 2025 9:07 pm
PostPosted: Tue Jul 28, 2020 10:54 am
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
If I were to use a Mopar 528 cam and 340 spec springs, how much would I need to have trimmed from the top of the valve guides? (or suggested amount??)
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Tue Jul 28, 2020 11:44 am
Someone might know a number, but you need to check your combination.
Most of the time, cutting for a better seal will get the clearance you need.
A seal like the teflon style, not the rubber style.
PostPosted: Tue Jul 28, 2020 12:02 pm
.100" is my go-to for guide trimming, but you should install a valve and retainer to see what your gross clearance is now and subtract the height of the seal you'll use for the net clearance.
PostPosted: Tue Jul 28, 2020 1:21 pm
Yes, measurement is best, but 0.125" is a good ballpark. Careful you do not coil bind those 340 springs too. Not sure they can take that lift number. Good to see you on the site!
PostPosted: Tue Jul 28, 2020 2:21 pm
340 springs are right on the edge with that cam. As Lou said, make sure to check coil bind.
PostPosted: Wed Jul 29, 2020 9:16 pm
Thanks for the input! I'm going by what's on hand as far as valve springs go. I heard they need to be cut after the lift goes above .450...but I don't how much truth there is to that.
