It is currently Tue Nov 18, 2025 4:13 am
PostPosted: Sat Aug 29, 2020 5:00 pm
Has anyone successfully used a standard-depth aftermarket 727 pan that has a drain plug?
I tried one once on a 1974 D-100 and the drain plug assembly touched the filter, so I sent it back.
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Sat Aug 29, 2020 5:14 pm
Poor-quality parts = poor-quality results. Use this pan and this gasket, real nice factory parts, and you'll be all smiles.
PostPosted: Sat Aug 29, 2020 7:16 pm
Do you know of a good standard capacity pan?
PostPosted: Sat Aug 29, 2020 9:14 pm
That is the standard-capacity factory pan for later models. You could just go ahead and use it, all you'd have to do is add a bit more ATF to bring the level up to Full on the dipstick. No other parts or adapters are needed.
Or you could scrounge around and try to find a 1962 or 1963 727 trans pan; those had drain plugs…but good luck with the search!
