It is currently Sun Nov 16, 2025 10:10 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 18, 2020 2:40 am
Funny you mention a microsquirt as ive been following builds w that on the 4200 inline 6’s and wondered about throwing one on the boys slant so he cant screw up w a carb.
Im not sure if its bc i was only running half the carb or not but when it was pulled from the truck it had been running 10# all day, which was on a stock rebuilt motor w oversized pistons. So id venture to say with proper fuel, 10# will run all day long. Now as far as keeping it that low on boost it may very well need an external. Yeah i was surprised too that they didnt have a hole drilled in the divider from the get go. Ill make sure to hunt down the microsquirt write up as i do have an electronic FI Tech carb up on the shelf now. Might be a good candidate for a swap onto it.
Always did want to see what 15# felt like. 10 alone was quite fun.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
