It is currently Mon Nov 17, 2025 11:11 pm
Post new topic  Reply to topic  [ 270 posts ]  Go to page Previous 113 14 15 16 17 18 Next
PostPosted: Thu Dec 31, 2020 5:22 pm
Robert's head pictures.
That's really the chamber shape he wants? :cry:
PostPosted: Fri Jan 01, 2021 3:33 am
Car Model: 1964 Valiant
I don't think making a head is that tough...it's a lot of machining but not tough.
Except for one thing....water jackets. Those are internal while the rest of the head is external. So the challenge in making a head, or welding up an adapted head, is getting the water jackets to not leak and to be properly placed. The beauty of casting is it allows you to make internal passages.
So will his head fit? Yes. Will it run? Yes. Will it run for hours and hours with no cooling issues? That's the $64,000 question.
I don't think this one will have water, but we shall soon see! The similar-to-OEM head I thought might work is a "fat head" with raised intake ports and water box on the driver side - cross drilled and welded. I'm glad Mr Maw is making progress.
PostPosted: Fri Jan 01, 2021 6:11 am
No water? Is it a drag only head?
PostPosted: Fri Jan 01, 2021 11:25 am
When the project started he was going to put it on an aluminum block, not sure how drag race friendly that would be?
He has also posted about doing a billet block.
PostPosted: Fri Jan 01, 2021 11:28 am
Didn't he have plans to eventually do 3 different versions of his alum head?
PostPosted: Fri Jan 01, 2021 12:30 pm
Car Model: Valiant -66 turbo
Would it be possible to cast a piece of aluminum, with the water jackets from beginning ?
And then machining it how you want it .
Thomas
PostPosted: Fri Jan 01, 2021 1:45 pm
Cast 50,000 heads? The first head is very expensive, the last head is almost free.
Cast one head? See above.
PostPosted: Fri Jan 01, 2021 4:24 pm
I understand, its a lot of work /money to cast a finish head.
But just to make the process more easy , just mold for the water jackets.
And then cast a piece of aluminum ( with water jackets inside..) to process in the cutter.
It was just a thought , :wink:
PostPosted: Fri Jan 01, 2021 7:04 pm
2 piece head with cooling passages between the 2 parts.......................
PostPosted: Sat Jan 02, 2021 10:11 am
Car Model: Road Runner
for a cooled head, 2 piece is the way to go. Then glue it together.
PostPosted: Sat Jan 02, 2021 11:05 am
Why would you want an aluminum street head?
PostPosted: Sat Jan 02, 2021 1:22 pm
Better heater in the winter?? :wink:
PostPosted: Sat Jan 02, 2021 3:27 pm
? Everyone alive wants aluminum street heads
PostPosted: Sat Jan 02, 2021 5:07 pm
Not me.
PostPosted: Sat Jan 02, 2021 5:21 pm
To expand the market for Ryan's MLS head gaskets!! :D :D
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
