It is currently Mon Nov 17, 2025 8:24 pm
PostPosted: Sun Feb 21, 2021 6:22 am
Car Model: 1968 Barracuda - Fastback
I bought a set of 10" front drum brakes for my '68 Barracuda to upgrade from 9", but I'm having difficulty verifying the parts are all matching. Wondering if anybody knows what the casting numbers on these parts correspond to, and if they're all compatible...
So, I'm throwing my coin in the fountain-of-knowledge and hoping for a miracle ;)
Here's what I have...
>Brake Backing Plates: both read 606 / L8
>Spindles: both have 3402738 with one ending in 191 and the other 188
>Hubs: one reads KH9, with the other H91042. In both cases, numbers are obscured by the studs. Both hubs are SBP hubs.
>Brake Pads: as installed measure 2.5" in width
>Wheel Cylinders: one read 3699927 / T12 & 3699926 / T15
That's all I know - hopefully, someone can fill in the details.
Thanks in advance!
-Chris
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Fri Mar 05, 2021 2:32 pm
2 1/2" inch brake pads sounds like '73 and later stuff.
PostPosted: Sun Mar 07, 2021 5:39 am
Yes indeed. Would you know if they all match (are compatible)? I'm guessing they do, but would like confirmation before hitting the road... ;)
PostPosted: Tue Mar 09, 2021 7:49 pm
I don't think the spindles will work with your upper control arms. You would have to try them on for figment.
