It is currently Mon Nov 17, 2025 6:44 am
 Post subject: Holley Sniper 1BBL
PostPosted: Sat Nov 07, 2020 2:25 pm
Car Model: 1964 Dart 270
Looks like Holley has a 1BBL sniper now. Autolite 1100. Even looks like it could be adapted to early throttle rod linkage.
https://www.holley.com/products/fuel_sy ... ts/550-552
____________________________
https://www.flickr.com/photos/162600228@N03/
 Post subject: D
PostPosted: Mon Nov 09, 2020 7:16 pm
D
 Post subject: Re: Holley Sniper 1BBL
PostPosted: Mon Nov 09, 2020 10:51 pm
If you are considering that Holley sniper system, for only a little more money and effort you can go MPFI instead of TBI:
https://www.stinger-performance.com/sto ... management
PostPosted: Wed Feb 24, 2021 12:36 pm
For the price of the Holley 1 barrel system I could adapt propane and pocket a chunk of change.
PostPosted: Fri Mar 19, 2021 5:24 am
Car Model: Slant Six M37
What are the benefits of propane, other than when being used in a building, or in off camber situations?
PostPosted: Fri Mar 19, 2021 9:37 am
Propane burns very cleanly. It is a dry fuel so it will not wash oil off the cylinder walls nor dilute the oil. Compared to a carbureted engine a propane engine tends to last much longer due to these factors. Propane is mostly one compound. This means that there aren't the same amount of light and heavy fractions that evaporate or congeal as you would find in gasoline. If you have ever been inside a Propane fueled engine you will find that they are very clean. Propane lasts a long time because it is in a gas tight container and can't evaporate or oxidize. Most standby generators up to around 80 kW tend to be propane. Larger units are usually diesel and prime power units are usually diesel although natural gas is also a player.
PostPosted: Fri Mar 19, 2021 3:10 pm
I've thought about converting one of my vehicles to propane before. I think I'd want dual fuel capabilities, being able to run plain ol regular gas as well as the propane
Users browsing this forum: No registered users and 27 guests
