It is currently Tue Nov 18, 2025 4:05 am
PostPosted: Tue Aug 31, 2021 10:18 am
Are the throttle rods the same for a 225 and 170?
I now have one of each and was curious about the interchangeability. Did '65 and '66 also use the throttle rod or did it get changed to a cable type assembly?
Thanks,
PostPosted: Tue Aug 31, 2021 2:26 pm
65 Slant 6 had the rod, V8 had cables. I think 66 changed to all cables but I am not sure.
PostPosted: Wed Sep 01, 2021 11:13 am
The only pre-'67 LHD Slant-6 A-bodies that had cable-type throttle were those with factory air. All others had the rotating-rod setup, in which some parts are different for 170 vs. 225.
PostPosted: Wed Sep 01, 2021 3:09 pm
Cool.
Thanks for the info.
Sorry for so many questions, no one around gere knows or cares about anything for these cars.
I appreciate the resources!
PostPosted: Wed Sep 01, 2021 6:53 pm
Thanks,
No they are different lengths 170 is shorter than 225 because of the deck height difference of the block.
63 Plymouth Valiant Wagon
Users browsing this forum: Ahrefs [Bot] and 9 guests
