It is currently Mon Nov 17, 2025 5:04 am
PostPosted: Tue Dec 21, 2021 10:20 pm
For our '75 Darts wiper linkage bushings, I have tried several factory MOPAR "NOS" bushings, but found that the "O" in NOS stands for "OLD": really, really old. The plastic crumbled easily when trying to install them. Back to Dorman 118-301 bushings. They fit, install fairly easily using a 9/16" socket and Channel-lock pliers or a C-clamp. The problem: they heat up and scream mercilessly. I've tried lubing the sockets before installation using Dow-Corning DC-4 silicone grease, and others using white lithium grease, or Lubriplate white grease. I have avoided using WD-40. My concern is finding a lubricant that works and won't attack the (Dorman) plastic compound, causing the bushings to disintegrate rapidly. I'm going to try LPS-1 or -2 next.
Any thoughts or tech help of lubricants here would be appreciated. P
PostPosted: Wed Dec 22, 2021 3:20 am
At least up until 5 yrs ago or so, you could get new Mopar bushings and they were very good. I wonder if a dry teflon-loaded grease like "dri slide" might work?
PostPosted: Wed Dec 22, 2021 3:51 am
I did one of my vehicles, about 1 yr ago. Used bushings from my local Mopar dealer. Those bushings come with a white lube, already in them.
PostPosted: Wed Dec 22, 2021 11:35 am
Both good info, Thanks. P
 Post subject: D
PostPosted: Wed Dec 22, 2021 5:20 pm
D
PostPosted: Wed Dec 22, 2021 9:47 pm
Thanks DI. A few decades? I'm getting about 6 years when they work. 6 days is when the latest started to squeal.
I'll let folks know how further trials turn out.
PostPosted: Fri Feb 04, 2022 8:55 pm
Out of frustration, today I disconnected all 4 plastic bushings and lubed them with just black moly wheel bearing grease. The squeal went away, but I'll watch to see how the grease affects the plastics.
Users browsing this forum: Google [Bot] and 8 guests
