It is currently Tue Nov 18, 2025 11:42 am
PostPosted: Thu Jan 13, 2022 12:31 pm
Hi Guys,
I want to try and work on this car more this coming spring and want to do a 10" drum upgrade. I kinda want to do a hi performance period correct type upgrade ie. the 10" Drums with drilled backing plate for coolong /venting and segmented brake shoes etc. Am I going to run into compatibility problems on the front end trying to change to 10" brake stuff?
The car is going to be a Nascar sport compact tribute. Can anyone advise if I can do this conversion with factory bolt ons?
The car is white with blue interior and it is a 3speed manual and it's gonna have a rowdy 170 hyper pak.
Thanks for your help!
PostPosted: Thu Jan 13, 2022 4:30 pm
If you're going to the effort and expense, your money is better-spent doing a disc swap. You wind up with much better, much less troublesome, much easier-to-maintain brakes.
Yikes. This idea sails right past the town of Unwise, cruises at triple the speed limit through Bad, and finally stops when it runs off the road somewhere in the City and County of Extremely Ill Advised. There are two holes in the backing plate as produced by the factory. They're oblong slots down at adjuster level, and they're to provide access to adjust the brakes without removing the drum. They're equipped with a tight-fitting rubber or plastic plug to keep water out, because drum brakes stop working when they get even a little bit wet, and even just one of those two oblong slots, without its plug, can let in enough water to make things bad. Let one side get wet and the other stay dry, touch the brake pedal, and the car will yaw hard enough to take the steering wheel out your hands. Don't go drilling new holes in the backing plates! This was a crude countermeasure for inherently inadequate brakes in racing service without risk of water entry. It did very little of any use even under those conditions, because there was no air movement through the holes. Seriously, don't do this; it is a staggeringly bad idea. Much more effective drum brake upgrades were heavier, finned drums (9" setup got these as standard fitment in '70; there were heavier/finned 10" drums as well, starting in 1973, though I am pretty sure they were all 4½" bolt circle.
If what you're trying to do is provide an escape path for the gases that emanate from hot brake friction materials and provide an air cushion between the shoe and the drum (which is one cause of brake fade), you can use a hacksaw to create two diagonal slots per shoe, not wider than the width of the hacksaw blade. Don't remove wider strips of friction material in the mistaken belief this will improve anything (it won't).
If you are bound and determined to stay with drum brakes, go fishing for NOS Velvetouch Metalik shoes (1962 test)
That warrants good brakes. Retro-tribute is fun. Retro-brake performance isn't.
PostPosted: Fri Jan 14, 2022 5:05 am
I agree that you will be MUCH happier and have less trouble and work with discs. Safety is not, IMHO, to be overshadowed by "period correct."
PostPosted: Fri Jan 14, 2022 5:29 am
Those Velvetouch brakes were the "cats meow" back in the day. It would be great if they could still be found. I had a set on a 66 Corvair with a 327 midships back in the '70's.
PostPosted: Fri Jan 14, 2022 6:42 am
All of the A body Factory drums available in Ø10" through 1976 were on the 4" bolt circle.
The 4 1/2" Bolt circle drums were found on other B/E/ C? Body cars like the Satellite, Belevedere, Savoy,Fury, Cuda / Challenger etc.
 Post subject: D
PostPosted: Fri Jan 14, 2022 5:25 pm
D
PostPosted: Fri Jan 14, 2022 6:19 pm
OK maybe I'd better tap the brakes on this idea......is the only option for a '60 and '61 A body front disc conversion the Scarebird setup? Maybe I will go this route and be done with it. Oh and upgrade from the 13"ers to 14" steel wheels OR maybe Minilites.
Thanks guys for reining me in on this one.
PostPosted: Sun Jan 30, 2022 11:03 am
As far as I know, the Scarebird kit is the only front disc conversion that keeps the small bolt pattern. This kit doesn't require removal of your spindle, so it's basically the same amount of work as converting to larger drums. It requires 14" or larger wheels (see the notes on the page I'm linking about caliper clearance on the stock 14" steel "poverty spec" wheels, though). This kit requires custom-drilled rotors, so just keep in mind you'll either be buying future rotors from Scarebird, re-drilling the (Toyota Previa?) rotors yourself, or getting them re-drilled by a competent machine shop.
https://scarebird.com/index.php?route=p ... uct_id=103
If you don't mind switching to the larger 5 x 4.5" bolt pattern, and you want even better brakes that use off-the-shelf components, then look into the later Mopar single-piston disc brake swap. This conversion requires significantly more work and some junkyard parts hunting. (It looks like the BigBlockDart website now requires a forum account to view the page linked below.)
https://www.bigblockdart.com/threads/di ... nfo.45857/
Escape Velocity Racing
