It is currently Tue Nov 18, 2025 1:47 pm
PostPosted: Thu Jan 20, 2022 1:45 pm
My question is if their is a 5 speed that will bolt on. Or what can I do for a faster top speed. 80 mph
PostPosted: Thu Jan 20, 2022 2:20 pm
Tell us more about your truck. Is the transmission an OD currently? What gear ratio is the rear. 2 barrel carb? Lean burn still on the engine?
No "bolt in" 5 speed
PostPosted: Thu Jan 20, 2022 2:27 pm
Even though there is no direct bolt in the np
A-535/nv2500 from an early dakota would be the most hassle free swap. Should use the same bellhousing clutch tob and everything else.
https://www.theedgeautomotive.com/produ ... drivetrain
Good luck!
PostPosted: Thu Jan 20, 2022 6:18 pm
That transmission bolts to a slant 6 bell?? Maybe I misunderstood.
PostPosted: Fri Jan 21, 2022 4:48 am
Charrlie should know for sure.. he has actually laid hands on these transmissions.. I have not.
I**(think)** the mounting bolt pattern and Bearing retainer is the same as the 833.. But I could be mistaken... Thinking for me is more like assuming... so Take it for what it's worth.
These transmissions are not too common although they have 1"x23 Input splines and other goodies similar to the 833 on the front end.
I wonder if the original poster has a NP435 or an 833 OD in his truck.
Some pictures of the transmission or shifter / hump area would be helpful.
top speed of 60 seems like some other engine issue - not the transmission.
PostPosted: Fri Jan 21, 2022 7:36 am
It's a slant six with 1 BBL carb
Not sure if it's in over drive. And how can I check the rear end? I could give you the vin would that help?
PostPosted: Fri Jan 21, 2022 7:39 am
I'll send a picture in a bit. What could be the engine issue?
PostPosted: Fri Jan 21, 2022 7:59 am
Could be anything from worn / Loose timing chain, valves, Rings, But more likely Ignition system / timing or Carb Tuning. Could be a bent push rod as well.
I doubt it's valve adjustment if it is a hydraulic Lifter Head and Cam/Valve gear.
PostPosted: Fri Jan 21, 2022 8:09 am
More than likely it's the push rods. How many push rods come in a slant six? 12?
PostPosted: Fri Jan 21, 2022 8:40 am
Yes there should be 12.
If you are actually missing a pushrod somehow, the engine would run horrible.
PostPosted: Fri Jan 21, 2022 8:49 am
Does this picture help
PostPosted: Fri Jan 21, 2022 8:58 am
Yes, that is the non overdrive transmission.
PostPosted: Fri Jan 21, 2022 9:01 am
So it's a NP435?
PostPosted: Fri Jan 21, 2022 9:40 am
So it's a NP435?
I have that trans in my '77 D200..
4.10 Rear Gear Ratio with 235 85 16 Tires
It will do 100Mph or more..
The engine is quite wound up but it will do it.
PostPosted: Fri Jan 21, 2022 4:04 pm
Also do you happen to know the size of the shift knob threads so I can buy another shifter.
Users browsing this forum: No registered users and 21 guests
