It is currently Tue Nov 18, 2025 2:12 pm
Post new topic  Reply to topic  [ 156 posts ]  Go to page Previous 17 8 9 10 11
PostPosted: Tue Nov 16, 2021 9:07 am
Thanks Rick That is a good resource for sure.
It does not give the spline length from a a fixed point. That is really the issue here..
I have some transmissions.... I will need to get to measuring them soon.
PostPosted: Fri Mar 18, 2022 4:12 am
Car Model: 1961 Dodge Lancer 770, 1938 Dodge Business Coupe
Is Ram going to produce a single disc set up to fit its flywheel?
I really don’t need a clutch capable of handling 600 hp or more.
A single capable of 350-400hp 300-350 lbft of torque is more than strong enough and I’d like to keep the spinning weight down.
61' Lancer 4 door shaved .200 ported polished,Balanced, Hyper-pak ,Headers,dual 2.5", 4 speed, 3.23 posi 8 3/4",205 70
PostPosted: Fri Mar 18, 2022 7:53 am
I think they produced one for a stock flywheel....
Lemme do some diggin' to see if I can come up with something...
PostPosted: Fri Mar 18, 2022 9:52 am
Here is some old info from AndyZ
https://www.slantsix.org/forum/viewtopi ... ram+clutch
That part # is now defunct.
Maybe you can call them then see if they will make you one.
or try Falcon Clutch in New york.. they remanufactured a very nice 9" mcLeod Unit for me a while back.
If you give them your specs I am sure they can make a "beskpoke" clutch for you.
PostPosted: Fri Mar 18, 2022 11:17 am
I have one from Falcon. It is a 9.25 built to factory 340 specs.
I also have a Ram Flywheel on the way that they say is drilled for their dual disc and a factory mopar 10” clutch PP.
The 9.25 and 10 have the same bolt pattern so it should bolt on but
I just like the added piece of mind of brand new clutch parts vs rebuilt.
I’ll call them and see what the scoop is.
Having not seen the 9.5 pressure plate for the dual system, I don’t know if that could work with a single disc without the center plate and second disc.
PostPosted: Fri May 06, 2022 3:34 pm
Car Model: 1964 Dart GT
I just saw this. Sorry, been busy.
If there are a few that definitely want one, we can ask for a group buy. Ram typically does their “special projects” in December or around the New Year. If we can get a number of participants, I will be happy to ask.
AndyZ
Users browsing this forum: No registered users and 17 guests
