It is currently Thu Nov 20, 2025 1:47 am
Post new topic  Reply to topic  [ 1866 posts ]  Go to page Previous 1111 112 113 114 115125 Next
PostPosted: Mon Sep 26, 2022 6:16 pm
Car Model: 85 Dodge D100
That's great Rick! With all the new found power you'll be back to Red Lighting in no time! :D
PostPosted: Mon Sep 26, 2022 6:18 pm
Friends stab you in the back faster than anyone! :D
PostPosted: Mon Sep 26, 2022 7:21 pm
Good job Rick!
PostPosted: Mon Sep 26, 2022 7:22 pm
So the #2 venturi / jet install issue is that what you suspect was causing your high rpm flutter?
PostPosted: Mon Sep 26, 2022 8:18 pm
Yes instead of it pointing downstream and pulling fuel out, it was facing upstream and trying to shove fuel back up into the bowl.
PostPosted: Tue Sep 27, 2022 4:04 am
Congrats on that find!
Sometimes it can be the smallest detail that we overlook and come back to find it with hindsight being 20/20.
When you find it, it's the Ah-Ha Moment.
PostPosted: Tue Sep 27, 2022 7:17 am
Wonderful work and great to hear, Rick. Can't wait to see it fly at MM in a month!
PostPosted: Tue Sep 27, 2022 3:20 pm
I've had quite a few of those.
Headed to the garage to put my 4.86 gears in. Hope I can put them in the right direction! :D :D
PostPosted: Wed Sep 28, 2022 5:28 am
:lol: :lol: :lol:
PostPosted: Wed Sep 28, 2022 6:24 am
You can drag race in reverse with a reverse pattern valve body and it will all work correctly as you had planned!
PostPosted: Wed Sep 28, 2022 7:41 am
My Dad put the pig in an International dump truck upside down. Had 5 reverses and 1 forward.
I did the same thing putting the carrier in a Cub tractor. International seems to like having diffs on the centerline so they go together either way.
I don't think you can do that with an 8-3/4. :oops:
PostPosted: Wed Sep 28, 2022 8:18 am
With all your help I think I got it! :D
Sure glad I installed an exhaust system for normal driving around the neighborhood. It sounds awful (the tone) but it made it nice while running up and down the road for 3 hours Saturday. Then last night I jacked the car up to do my rear end change, and literally in 5 seconds the whole thing drops off on the floor. I like it! :D :D
PostPosted: Wed Sep 28, 2022 8:22 am
Pretty Cool Rick!
What a clean modified '65!
PostPosted: Wed Sep 28, 2022 11:27 am
Yes Rick's Car is Very Clean and a well thought out / put together car.
You should come see it in person at the end of the month at Fairlawn, VA.
PostPosted: Sat Oct 01, 2022 9:17 am
Good times today! Two of my Grandsons were in the garage with me. (Ages 11 & 15) They finished installing my conversion U joint, Installed my drive line, both axles and drums and wheels. And then they wanted me to fire it up (Open exhaust). They said it was loud. Look on their faces at 6000 rpm, priceless! :D :D
