It is currently Tue Nov 18, 2025 6:43 am
PostPosted: Mon Dec 19, 2022 7:04 am
When I removed my distributor (63 valiant, slant six), I only found one O-ring, the large one that fits in the block recess. I read somewhere that there are supposed t be two O-rings. True? If so, where does the second one go?
PostPosted: Mon Dec 19, 2022 9:19 am
Two; see here
PostPosted: Mon Dec 19, 2022 12:51 pm
Where does that second o-ring go? I do see a smaller one already in place on the dist shaft. Is that the one?
PostPosted: Mon Dec 19, 2022 1:21 pm
Locations are described in linked post: small/lower in distributor shank groove; large/upper just under hold-down plate.
