It is currently Mon Nov 17, 2025 10:43 pm
 Post subject: Help with HEI module
PostPosted: Sat Jan 14, 2023 4:35 pm
I have a 2000s cheby hei module with the 4 pin connectors oem they have 4 wires coming out, also im going to use a 80s ford coil and ive adapated the distributor for electronic ignition. Question will I also need a relay an if so how will i hook it up with a simple set up?
Gm part number GM 089 5A21
 Post subject: Re: Help with HEI module
PostPosted: Sat Jan 14, 2023 5:21 pm
Read the HEI upgrade article for particulars and details.
PostPosted: Sun Jan 15, 2023 8:31 am
I did but i didnt seem to find about the 4 pin connector
PostPosted: Sun Jan 15, 2023 10:06 am
The entire article is about the 4-pin module… ¯\_(ツ)_/¯
PostPosted: Wed Jan 18, 2023 4:49 am
Would you recommend adding a relay to the mix?
PostPosted: Wed Jan 18, 2023 9:11 am
Others will probably recommend one but I have 3 vehicles running without them and all have 13+ volts at the module. Been running them for 3-8 years
PostPosted: Tue Feb 14, 2023 11:10 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
I used a Delphi DS10071 module about 4 or 5 years ago. I have a couple of supposedly real AC Delco 4 pin modules somewhere but haven't needed them yet. I intended to install a relay but have never gotten around to it. I used a NOS GM coil with factory mount intended for a late 70's Chevette engine mount. I mounted the bracket on the fender in my truck. Got a couple of assemblies on ebay. I've forgotten the GM part no. for coil and bracket, but the coil is equivalent to the SM DR35.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
