It is currently Mon Nov 17, 2025 10:26 pm
 Post subject: Dash
PostPosted: Sun Jan 22, 2023 6:00 pm
Car Model: 1974 W100; 72 Dart
My 72 Dart has led a very hard life. The dash is questionable at best.
What sort of aftermarket things have yall done with the dashboards of an A-body. I am open to tinkering on this.
sb
 Post subject: Re: Dash
PostPosted: Mon Feb 13, 2023 8:12 am
I've removed a couple of dashboards, checked the gauge functions, replaced the bulbs with LEDs (making sure the polarity is correct), and painted the chromed plastic in black, and the silver with metallic silver. I polished the plastic lenses with toothpaste, and added a tachometer. I wasn't trying for a show car, so it looks OK, and everything works.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Tue Feb 14, 2023 8:37 am
Contributor
I went with a modern gauge replacement on my '64 Valiant. Pricy and lots of work, but I'm satisfied with the results.
PostPosted: Tue Feb 14, 2023 2:12 pm
Did you do the new gauges yourself? If so what kind were they. I think they look right at home. :D :D
PostPosted: Tue Feb 14, 2023 5:55 pm
Contributor
They are from "New Vintage USA" and are made in Michigan. I shopped several gauge manufacturers and decided the NV faces looked the closest to the original '64 Valiant gauges.
I liked them so much that I am also using another set of a different series that looks era-appropriate for my '56 Plymouth project.
ttps://newvintageusallc.mybigcommerce.com/
