It is currently Mon Nov 17, 2025 10:23 pm
PostPosted: Wed Mar 08, 2023 8:17 am
Car Model: 1980 D150
Hello,
I am looking for guidance on the following swap.
My 1980 d150 Slant 6 exploded in spectacular fation. It has a 3spd Auto attached to it.
I found a engine from 1972 similar to mine. But it has a 4 spd Manual gearbox attached to it.
My question is , can i Swap the engine without modification to fit on the Auto trans ?
PostPosted: Wed Mar 08, 2023 8:34 am
Yup
PostPosted: Wed Mar 08, 2023 11:09 am
Well that was easy.
Thanks for the quick answer.
PostPosted: Wed Mar 08, 2023 11:23 am
If included with the motor, 4 speed manual gear boxes and bell housing can be worth a few dollars. Particularly the short tail 4 speed or three speed with over drive have some value.
Back to your ‘exploded engine’ if the replacement motor is from a car you will need to swap over the truck rear sump oil pan and oil pick up.
PostPosted: Wed Mar 08, 2023 2:43 pm
I sent you a PM.
