It is currently Tue Nov 18, 2025 6:36 pm
 Post subject: 2 barrel options
PostPosted: Mon Mar 13, 2023 11:41 am
Car Model: 1973 Scamp 225
Hello all, I've been reading on here about 2 barrel options, I have just found a factory cast iron 2 barrel manifold. I've been trying to work out Carter serial numbers but not sure what model would be most suitable. I have a 73 Scamp auto that is pretty much factory standard. I'm in the UK so finding parts is going to be a challenge, although new Weber's are readily available.
Thanks - Chris.
 Post subject: Re: 2 barrel options
PostPosted: Mon Mar 13, 2023 1:29 pm
Chris,
I suggest you contact SlantSixDan as I believe he said he has some new-old-stock Carter BBD 2bbl carbs that he can sell. Those are great carbs if you can find a good one.
PostPosted: Mon Mar 13, 2023 2:58 pm
Bendix-Stromberg WW 2bbls, they are. At least as great as (greater than, in some respects) the Carter BBD. Send me a PM if you like, and I'll see what I still have.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 26 guests
