It is currently Mon Nov 17, 2025 11:11 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Fri May 26, 2023 12:59 pm
Their bearing catalog from my research seems a bit confusing.
Maybe I need to look again... or find a print version of the catalog
PostPosted: Fri May 26, 2023 1:03 pm
I had a set of King mains for a forged crank. Unfortunately they are in Iowa now.
I had the machine shop get them last year. It took 6 weeks for them to show up.
PostPosted: Fri May 26, 2023 1:17 pm
They were on E bay not to long ago. Summit racing also had them.
PostPosted: Fri May 26, 2023 6:00 pm
Online
King Main bearings forged crank MB 407 AM
King Rod bearings forged crank CR 614 AM
That is from bearings I have on the shelf std size
PostPosted: Fri May 26, 2023 8:08 pm
Some conventional ( and conservative) wisdom from one HD diesel engine manufacturer’s Engineering Group is:
Steel crank, use a tri-metal bearing. Steel cranks and tri-metal bearing have been around together since babbit bearings were phased out. Lots of history there. Clevite is a tri-metal bearing.
Cast crank, use a bi-metal bearing. Cast cranks and bi-metal bearings were developed during the same time frames. King Bearing produces bi-metal bearings.
This does not mean that tri-metal bearing won’t function on a cast crank or that bi-metal bearings won’t function on a steel crank. Clearances and cleanliness are more important. The thought in matching steel and tri-metal and cast and bi-metal is, if it’s working and has worked for a long time, leave it alone.
PostPosted: Tue May 30, 2023 8:56 am
SL6 Racer
I used 440 Source steel main caps in several of my engines. Little work to the thrust cap and a line bore.
Line bore wasn't cheap. Had to remove a bunch of material which was steel.
Dave
PostPosted: Tue May 30, 2023 10:54 am
Thanks, Dave! Maybe I will do this on my upcoming turbo/stroker shortblock build...
Anyone try to do the side-bolted main caps for the Slant? Just curious.
PostPosted: Tue May 30, 2023 2:34 pm
Thank you! That's what I was trying to find.
1963 D100: 3-on-the-tree, 3.50 rear, mostly original, stainless bore clutch slave & brake master, rebuilt speedo, original rebuilt carb.
1961 D200: crew cab short bed, sold.
1965 D500 Crew Cab, planning a 6V92 swap and 6x6 conversion.
PostPosted: Tue May 30, 2023 3:30 pm
Online
Your welcome. You should have seen the look on the face of the King rep when I asked for Slant six forged crank engine bearing set, when I won the door prize at a King seminar at the PRI show. :wink: :wink:
PostPosted: Tue May 30, 2023 6:57 pm
How would a side bolted cap work on a slant? It seems that the pan rails would nor be low enough for that.. maybe a 4 bolt splayed cap?
PostPosted: Wed May 31, 2023 3:34 am
Yeah, probably would need quite a bit of customization work, but who knows. Doubt there's enough meat in the side webs to do another splayed bolt. Just thinkin...
PostPosted: Wed May 31, 2023 6:13 am
Girdle.
PostPosted: Wed May 31, 2023 6:52 am
Honest question, how many times have you seen someone beat the mains out of a Slant anyway? The block/crank seem pretty tough to start with.
PostPosted: Wed May 31, 2023 8:49 am
Car Model: 64 Valiant
Main straps would be a good upgrade and just as effective while being more economical, but these blocks and cranks are so robust compared to other inline engines like the Ford or Chevy counterparts, I doubt you would gain any benefits as long as the production cylinder head is the limiting factor...
PostPosted: Sun Jun 04, 2023 5:00 am
I am aware of a few broken blocks at high HP levels (boost/N2O) and/or RPMs. Plenty of high HP Slants have lived without these, of course. I have never worried about this, but am starting a build where I want a reliable 450-500 HP on boost with a stroker crank and thought this would add insurance. Just thinkin...
Users browsing this forum: Bing [Bot], Google [Bot], slantzilla and 14 guests
