It is currently Tue Nov 18, 2025 1:59 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Fri Jun 16, 2023 4:19 pm
PostPosted: Fri Jun 16, 2023 4:25 pm
Blue line plastic pump arm can wear or have hair line cracks. Green line wear pattern on steel s pin wear pattern. The s pin mloves in and out of pump shaft with up and down. movement. Check for burrs or smooth with file
PostPosted: Fri Jun 16, 2023 9:21 pm
Car Model: 78’ dodge D100 slant six
Is there any place to get these plastic parts?
PostPosted: Fri Jun 16, 2023 11:05 pm
https://quadrajetparts.com/linkage-c-299_302_330.html
PostPosted: Fri Jun 16, 2023 11:07 pm
Looks like there out of service. Try walker next
PostPosted: Fri Jun 16, 2023 11:37 pm
https://www.ebay.com/itm/120345764441?h ... R5LYyYCZYg not the right one ,there were long and short yours is different. Thats carter number 111-120, you need carter 111-165 pump arm
PostPosted: Sat Jun 17, 2023 6:54 am
https://www.carburetion.com/Products/Pr ... t=BBD-HV32 This looks right
PostPosted: Tue Jun 20, 2023 12:28 pm
Thanks so much! That site also has the other piece as well. Can you tell me if it’s the correct one as well?
https://www.carburetion.com/Products/Pr ... art=85-182
PostPosted: Tue Jun 20, 2023 4:53 pm
That looks good to me , walker number here better picture https://www.ebay.com/itm/120345763180?e ... R-jQuq2bYg carter number 111-118 for v8 but will work in slant models just a little more mid throttle lift of metering rod,good with todays fuel.
PostPosted: Tue Jun 20, 2023 5:09 pm
slantsix bbd most of time got this one,not as much metering rod lift at mid throttle, after market only services v8 model https://www.ebay.com/itm/403598194643?e ... R6TgoLSbYg
PostPosted: Tue Jun 20, 2023 5:23 pm
factory slant six green one https://www.ebay.com/itm/334859698709?_ ... %3A2047675
PostPosted: Tue Jun 20, 2023 5:33 pm
After market also came in black v8 type 111-118.https://www.ebay.com/p/2098143223
