It is currently Wed Nov 19, 2025 5:33 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Tue Feb 12, 2019 10:47 am
The 2bbls were called "supersix" and mostly were offered in the 70s and 80s, but did not have a higher HP rating even though they undoubtedly had higher HP
The 2bbl setup offered in the US and Canada from '77-'83 was called Super Six (two words) and in every year it was offered it had a higher advertised horsepower rating, 110 vs. 100 net hp. If you compare the earlier gross horsepower ratings, 160 vs. 145, that is also right at 10%.
PostPosted: Wed Jun 21, 2023 7:55 pm
Car Model: Dodge Polara RT 1974 and Valiant V200 1962
In Argentina, 3 enhanced Slant Six varieties were marketed:
Valiant 3 and 4 GT, from 1965 to 1967, the base is the Slant Six 225, but with a preparation whose main characteristic is its double carburetion, different cam and 8.1:1 producing 180 HP and 304 nm or 224 lbft of torque, with a performance of 162 km/h of final speed and a 0 to 100 km of 12 seconds.
I leave you the period tests: https://www.testdelayer.com.ar/valiantgt.htm
Last Valiant 4 GT, Dodge GT and Dodge GTX 6 cylinders: in September 1967 until 1972 the prepared Slant Six was reconfigured, leaving aside the double carburetor and going to the double-mouth crankcase "configuration similar to that of the super six", this The engine was the 225 with a 2-barrel carburetor, different cam, a compression of 8.4:1 and produced 155 HP and 294 Nm or 216 lbft of torque, with a performance of 170 km/h of final speed and 11 sec from 0 to 100 km.
I leave you the period tests: https://www.testdelayer.com.ar/dodgegt.htm
Dodge Polara RT: at the end of 1973 the Dodge Polara RT debuts, it came equipped with the best performance Slant Six produced in Argentina, the Slant 225 with a new two-barrel Holley 4040 carburetor, 3a1 3a1 exhaust manifolds, a cam with 22º crossover, 8.5:1 compression ratio and produced 174 HP and 333 Nm or 246 lbft of torque, with a final performance of 182 km/h and 0 to 100 in 11 sec.
I leave you the period tests: https://www.testdelayer.com.ar/dodgepolarart.htm
and a picture of the engine:
File comment: Dodge Polara RT
PostPosted: Thu Jun 22, 2023 3:03 pm
Super cool! Thanks for sharing that from Argentina.
PostPosted: Fri Jun 23, 2023 3:09 pm
The Argentine Polara is a beautiful car.
There are several YouTube videos on them. One of the most interesting the the guy with the "fender well" headers and a 2' tall adapter for his Weber carb. It does nice burn outs and they rev the snot out of the engine. I guess there is no V8 guys telling them you can't do that with 4.125" cranks.
PostPosted: Fri Jun 23, 2023 8:51 pm
People cover their ears when I'm in the waterbox. :mrgreen:
PostPosted: Sat Jun 24, 2023 11:14 am
Thank you for the Argentinean info.
Can you post any pictures of that Dodge Polara engine with the air filter and housing removed?
I would sure like to see the induction and exhaust setup.
¡Gracias¡
PostPosted: Sat Jun 24, 2023 2:52 pm
For sure the slant 6 option would have been more popular if they had that extra 30-40 hp. :D
PostPosted: Wed Aug 09, 2023 6:55 pm
¡Gracias¡
of course, here is a picture. It should be noted that the photos are of a group of Argentine Dodge
PostPosted: Wed Aug 09, 2023 7:06 pm
I think so, the performance of the Slant Six of the Dodge Polara RT was outstanding.
PostPosted: Wed Aug 09, 2023 7:09 pm
¡Gracias¡
another photo
PostPosted: Thu Aug 10, 2023 7:04 am
Very cool! Love those exhaust manifolds.
PostPosted: Thu Aug 10, 2023 2:21 pm
That's a cut/capped rear half of a stock exhaust manifold, along with this front-3 casting, which…if I recall correctly, Lou, didn't you buy the linked one off me?
PostPosted: Fri Aug 11, 2023 6:08 am
I think Rick bought it, or I bought it and sold it to someone else. It was in my garage at one point to check intake fitments...
PostPosted: Fri Aug 11, 2023 6:28 am
Lou I had it to measure and photograph along side the Hyperpaks. I think maybe Stan ended up with it?? :D
PostPosted: Fri Aug 11, 2023 8:18 am
Lou I had it to measure and photograph along side the Hyperpacs. I think maybe Stan ended up with it?? :D
I had something witty to say, but I will just keep it in my head.
Cool Manifold, however.
Maybe we need to make a slanted Pilmrigage below the Darien pass someday! :D :D :D
:mrgreen:
