It is currently Mon Nov 17, 2025 2:28 am
 Post subject: Front Door Alignment
PostPosted: Sun Sep 17, 2023 9:29 am
63 Valiant, 2 door. I need to adjust the passenger side door a little, and reading the manual, it's not all that clear... It mentions "hinge straps", whatever that means (hinges?) So.... is alignment done using the bolts on the door side hinge bolts , or the bolts on the body side, accessed through the inside kick panel? I just want to be clear on tis. Thanks.
 Post subject: Re: Front Door Alignment
PostPosted: Mon Sep 18, 2023 6:48 am
I would imagine it is done with the front fender off. then the fender is hung adjusting to the gaps on the already set door.
I am no body man but that is my guess.
PostPosted: Mon Sep 18, 2023 7:18 am
The gaps aren't the problem; I just have to raise the door a little at the rear, which can only be done with the hinge bolts loose. I just need to verify that the bolts are loosened from inside the car, through the access holes behind the kick panels. Rather awkward if that's the case.
PostPosted: Mon Sep 18, 2023 7:30 am
I cannot remember if the bolts are accessed on the inside or outside of the pillar. Best to remove the kick panel and see.
PostPosted: Mon Sep 18, 2023 2:51 pm
Yes I think that is correct.
PostPosted: Tue Sep 19, 2023 4:26 am
Yep, the bolts have to be loosened from inside the car; I got it done last night. Thank you!
