It is currently Mon Nov 17, 2025 3:18 am
 Post subject: Exhaust Hardware
PostPosted: Fri Sep 22, 2023 4:12 am
Car Model: 1983 d150
I have a 1983 d150 with a slant 6 I am trying to locate studs and nuts for the manifold intake exhaust can anyone help me out or at least give me the correct size Thanks
 Post subject: Re: Exhaust Hardware
PostPosted: Fri Sep 22, 2023 4:26 pm
There have been several threads on this question, including a few that show places to buy at a deal. Do you have the triangle washers at least?
Oh yeah forgot to ask are you looking for the ones to hold the manifolds to the engine or the ones that hole the manifold stack together?
PostPosted: Fri Sep 22, 2023 5:43 pm
Silver seal is where I always order the studs for the head.
PostPosted: Sat Sep 23, 2023 4:35 am
I have looked for days on the internet I cannot find the studs in the washers the conical washers I need the one to connect the exhaust and the intake manifold to the Head I search silver sale and I do not know the size that I need is the problem
PostPosted: Sat Sep 23, 2023 4:55 am
I will try and get you a part number from them later today
PostPosted: Sat Sep 23, 2023 5:13 am
I have searched any threads that I seen dealing with exhaust I found none that told me where I could buy them from or the size someone said silver sealI did look at Silver Seal but they do not do it by car application
I do not know the size that I need The only triangle washer I see is on valve cover. Thanks
PostPosted: Sat Sep 23, 2023 5:30 am
First question: Do you need the hardware that bolts the intake manifold to the exhaust manifold?
Or do you need the hardware that holds both manifolds to the head?
PostPosted: Sat Sep 23, 2023 5:43 am
The studs are 5/16-18 x 1/2, 5/16-24 x 3/4 overall length is 1 3/4 inches.
PostPosted: Sat Sep 23, 2023 6:12 am
I am pretty sure silver seal discontinued that part#.
I bought a bunch on clearance a year or 2 ago.
Mcmaster- carr had a nice substitute with internal hex ends like arp studs.. they were about ~$70 for an entire engine set a few years ago.
I would have to dig around to find the part #.
PostPosted: Sat Sep 23, 2023 6:24 am
Hereis the previsouly provided discussion on such things.
Studs: https://www.mcmaster.com/thread-adapter-studs/
Nuts Plain: https://www.mcmaster.com/94820A240/
Nuts Fancy: https://www.mcmaster.com/99638A300/
Just get yo'self some triangles and you are ready to go.
Badvert from this site also has the hardwarefor sale in his ebay store.
PostPosted: Sun Sep 24, 2023 3:39 am
Greg thank you so much !Badvert had them
PostPosted: Fri Sep 29, 2023 9:33 pm
Car Model: 1964 Dodge Dart GT Convertible
Not sure if this full slant bolt set has the quality your hoping for but price looks fair.
https://www.ebay.com/itm/311904435994?m ... media=COPY
PostPosted: Sat Sep 30, 2023 10:05 am
That's the bolt set I bought a couple of years ago, wasn't that expensive then.
PostPosted: Sun Nov 26, 2023 7:03 pm
Car Model: A couple slant six mopars and other mopars
https://www.dormanproducts.com/p-26874- ... in=keyword
Dorman675-092
List as 5/16-24x7/8 & 5/16-18x9/16 and 1 3/4" long Box of ten
675-520 1 1/2" long
675-094 2 1/2" long
675-093 listed as 2" long but came short at 1.400" long
29129 Stud-tite 2 pc with nuts- correct but discontinued
Users browsing this forum: Google [Bot] and 12 guests
