It is currently Mon Nov 17, 2025 12:29 pm
PostPosted: Mon Oct 23, 2023 8:30 pm
Car Model: 1967 D100
Hello hive mind, I'm hoping I can get some thoughts as I take on a radiator replacement. Specifically, what do you recommend I do, or keep in mind as I take this on? I plan on getting a Champion radiator, with overflow tank. Comes with a 13lb cap and, so it says, a transmission cooler (do I need a transmission cooler?). I'm planning on a new water pump, all the hoses, thermostat. I'm assuming I'll stick with the existing fan setup, unless you advise another plan. I don't intend to soup this thing up, just to keep it going and hopefully make it better....
Is there anything else you'd recommend whilst things are apart? Anything I should be cautious of? BTW this is going into a 67 D100, stock everything.
I appreciate your ideas - thanks tons in advance.
Cheers - Jason
1967 D100 225ci 3spd manual stock AF
PostPosted: Tue Oct 24, 2023 4:53 am
Car Model: '23 T-bucket
Cheers - Jason
That depends.....is it an auto trans? If so, then yes, there's a cooler in the bottom of the radiator.
Roger
PostPosted: Tue Oct 24, 2023 6:37 am
Champion rad is great. If you have auto trans, then get the cooler, yes.
PostPosted: Tue Oct 24, 2023 6:47 am
I think almost all of the Champion Radiators have a trans cooler installed. If you don't have a automatic trans, just leave the plugs in the cooler connections.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 15 guests
