It is currently Mon Nov 17, 2025 6:14 am
 Post subject: Turning the crank
PostPosted: Tue Nov 28, 2023 7:27 am
My 63 VAliant: How do I turn the crankshaft by hand? very little room between the radiator and the crank pulley.
 Post subject: Re: Turning the crank
PostPosted: Tue Nov 28, 2023 7:39 am
Use the fan blade to turn it, and be sure you have the belt and alternator installed. Hand tension the belt more if it slips.
Works great unless you have a declutching fan, which should not be an issue with your car.
PostPosted: Tue Nov 28, 2023 8:09 am
Manual?
You can put it in gear, and pull or bump the car and it will turn.
Plugs out and it turns eay.
Users browsing this forum: Bing [Bot] and 16 guests
