It is currently Mon Nov 17, 2025 8:57 am
Post new topic  Reply to topic  [ 119 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Sun Jan 07, 2024 8:02 am
Car Model: 1983 Dodge D150
PostPosted: Sun Jan 07, 2024 9:13 am
No intake or exhaust gasket I could see.
It should have one for sure. :?: :?:
PostPosted: Mon Jan 08, 2024 4:09 pm
Measured a couple of cylinders at 3.403 to 3.405 real quick just now. It might clean up with a straight hone but guessing I'm looking at getting the block bored. I'm going to finish dismantling the engine this week and try to get the block to the machine shop by Friday.
Would you just bore to clean up or go big?
Too late to get in on the forged piston buy?
PostPosted: Mon Jan 08, 2024 4:15 pm
I'd bore as big as you can get pistons for.
PostPosted: Mon Jan 08, 2024 4:41 pm
I go opposite way. Bore the least amount that cleans things up that you can get pistons and rings for.
PostPosted: Thu Jan 11, 2024 4:02 pm
No other bolts holding this on? Not wanting to come off.
PostPosted: Thu Jan 11, 2024 6:00 pm
Use this type of puller (do not grab the outer ring) https://www.oreillyauto.com/detail/c/do ... iser?pos=5
Thread the three bolts into the hub of the balancer. Put something (bolt, piece of metal stock, etc) into the threaded hole in the crankshaft to protect the threads, and have something to push against. When you get the balancer off, I would either send it out to be rebuilt, or purchase a new one. That one is pretty well shot. The rubber is coming apart.
PostPosted: Thu Jan 11, 2024 7:12 pm
Thanks! I would not have thought about rebuilding or replacing the harmonic balancer.
I have a puller and it's off. It just needed a bit more torque.
Pictures of the #1 connecting rod bearings and piston. How does everything look? Crank measures 2.190, book says 2.1875. Maybe my mic is off, it's 20 years since a certification.
PostPosted: Thu Jan 11, 2024 7:16 pm
Forgot to add, rods and caps are not numbered. What is the best way to number them?
PostPosted: Thu Jan 11, 2024 7:22 pm
I have a number stamp set. Stamp them on the pads by the parting lines and you can make sure to get them back in the proper orientation too.
PostPosted: Fri Jan 12, 2024 5:17 am
I don't like "smacking" with a stamp. I always worry about distorting them. I use a etching marker. The kind that have a carbide point and vibrate..
PostPosted: Fri Jan 12, 2024 6:53 am
Was wondering the same thing about distorting them. I have a number stamp set. Stamp them on the crank for support?
PostPosted: Fri Jan 12, 2024 9:35 am
Didn't stamp them with numbers. Used an auto center punch and made dots 1 to 6. Got everything out of the block. Used an egg crate for the lifters. Got the idea here.
Picture of the main bearings.
PostPosted: Fri Jan 12, 2024 1:31 pm
That is what they taught us to do in school. 50 years ago! :D :D I still do that too.
PostPosted: Fri Jan 12, 2024 1:43 pm
Measured the main crank bearings at 2.190, 2.1875 is max in the SM. Maybe my mic is a bit off. The connecting rods checked a little big as well. I'm going to pull the valves tomorrow and check the head. Plan to haul it all to Midwest machine in Tulsa Monday.
I talked to the main guy there today. He mentioned they did a bunch of slants back in the day for Southwestern Bell. He wasn't familiar with milling .1 off the head/block though.
So do I have them order pistons? There is a ridge on some of the cylinders so it most likely needs bored.
Anything else I should look at?
Users browsing this forum: No registered users and 19 guests
