It is currently Sun Nov 16, 2025 8:10 pm
Post new topic  Reply to topic  [ 119 posts ]  Go to page Previous 1 2 3 4 5 68 Next
PostPosted: Fri Jan 12, 2024 2:30 pm
Car Model: 1983 Dodge D150
What to use for a oil pump gasket? I'm searching and the only thing I can find is the older 6 bolt gasket. Seems like there was talk here about a newer gasket that needed modified but I'm not finding it now.
PostPosted: Fri Jan 12, 2024 2:40 pm
Badvert65 on here makes a new gasket that does not need to be modified. They are really nice. Just drop him a PM or they may be on Ebay right now?
PostPosted: Fri Jan 12, 2024 4:42 pm
Awesome thanks! Sent a pm.
PostPosted: Sat Jan 13, 2024 5:59 am
I got lucky and found a 6 bolt pump, have never used a 5 bolt version. But as I remember it doesn't hurt anything to use a 6 bolt gasket for a 5 bolt pump "but I wouldn't go the other way" on this
I bought a 10 pack of old stock fel pro gaskets a couple of years ago. I've gotten 6 bolt pumps on eBay.
But for the future I think I will be rebuilding/reusing original pumps ... Look at old posts here, at one time there was a decent amount of talk about that subject....
PostPosted: Wed Jan 17, 2024 4:42 pm
Questions on reusing the cam. My brother mentioned mic ing the cam lobes and comparing them to each other. What other things to check? Do I polish up the lobes a little? Just get a regrind from Oregon Cams?
Really interested in longevity and fuel mileage as much as power.
Thanks.
PostPosted: Wed Jan 17, 2024 6:24 pm
Send yours into Oregon cams and let them regrind that one.
PostPosted: Wed Jan 17, 2024 7:25 pm
Oregon can also re cut your lifters so you can re use them.
PostPosted: Thu Jan 18, 2024 3:41 pm
Pictures of some lobes and the fuel pump lobe. Maybe this is beyond regrind?
PostPosted: Thu Jan 18, 2024 6:04 pm
Yeah that is pretty ugly.... Especially what I see in the top pic
PostPosted: Thu Jan 18, 2024 7:06 pm
The fuel pump didn't put out much. I now know why.
PostPosted: Thu Jan 18, 2024 7:12 pm
Talk with Ken at Oregon Cams, they can weld up worn fuel pump lobes.
Don’t know if yours is repairable, Ken would know.
PostPosted: Thu Jan 18, 2024 7:14 pm
I sent the pictures to Oregon Cams. Thanks.
PostPosted: Fri Jan 19, 2024 7:44 am
Timing chain replacement ideas? I've searched here a bit. Not sure I need a double roller set for a daily driver pickup. Do the cheap ones fail?
https://www.ebay.com/itm/174097276518?m ... media=COPY
Or a roller.
https://www.ebay.com/itm/263577823687?m ... media=COPY
PostPosted: Fri Jan 19, 2024 9:44 am
For your street engine the standard one is fine.
PostPosted: Fri Jan 19, 2024 4:50 pm
Going with Oregon Cams. Welding up the fuel pump lobe.
What grind for a broad powerband? Thinking I'll stay with the single barrel 1945.
How much does a 2 barrel hurt gas mileage?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 15 guests
