It is currently Tue Nov 18, 2025 8:43 am
 Post subject: Distributor bushings?
PostPosted: Tue Jan 30, 2024 3:27 am
Where are you guys finding the bushings for the distributor shaft at? I have some to replace.
Thanks
PostPosted: Tue Jan 30, 2024 6:42 pm
Or does anyone have a part number?
PostPosted: Wed Jan 31, 2024 4:24 am
I looked in sever parts books, and the bushings are not listed as a separate part, only as a "housing with bushings". You could contact Halifax Hops. He is on FABO and rebuilds Mopar distributers. I'll send you a PM with his contact info.
PostPosted: Wed Jan 31, 2024 6:01 am
Thanks charlie
PostPosted: Wed Jan 31, 2024 10:14 am
Huh I thought I had a reply here that I ain't seeing pop up
Measure the shaft diameter, see if you can pop one out and measure the outer diameter of the bushing and the length,band hit up eBay
Is berry bearing still around by you? If anyone would have those it would be them. I'm sure something else besides the/6 uses such a bushing
PostPosted: Wed Jan 31, 2024 10:23 am
2275 228 and then 2585 021, but no sign of availability. They're plain old oilite bushings; just extract the old ones and match 'em up by size at the likes of McMaster-Carr.
PostPosted: Wed Jan 31, 2024 11:00 am
I have a big drawer full of distributors. I'm not sure I've ever seen one that was too loose to use, but maybe a couple out of the 100 I've had in my hands. We can likely find one for you.
PostPosted: Wed Jan 31, 2024 1:26 pm
No I have plenty. I was trying to teach Andrew how to go through them and rebuild/clean...etc. them. And his bearings have a good bit of play, so I just thought we would replace them and do it right. I have some in a box too if I need them.
PostPosted: Wed Jan 31, 2024 5:22 pm
These guys show both the numbers Dan posted; you might give them a call. https://www.amsnos.com/Default.aspx
63 Plymouth Valiant Wagon
PostPosted: Wed Jan 31, 2024 5:31 pm
Thanks to all! :D
PostPosted: Thu Feb 01, 2024 2:34 am
Dan, can you tell me where you found the part numbers? I checked a few part books, and didn't see them.
PostPosted: Thu Feb 01, 2024 12:19 pm
Part type code 8-27-133 . The later part number is in the '70-'71 FPC, and the earlier one is in the '63 FPC. No such type code in the '73 FPC, just housing-with-bearings.
PostPosted: Thu Feb 01, 2024 3:12 pm
Thanks, I just didn't look in the right year manuals.
PostPosted: Sat Mar 30, 2024 1:48 pm
I've seen those bearings from time to time pop up on different sites, but couldn't tell if they were for a slant cause i couldn't find them in my FPC. My dist. is a little wobbly, but haven't looked at it that close. I pretty much thought they were for 8's.
Off the top of youur head, are 74's supposed to have them?
Thanks, 74
Where ever you go there you are!
PostPosted: Sat Mar 30, 2024 4:30 pm
All-year distributors have them—\6 and V8. Chrysler stopped listing them separately in '72 or '73.
Users browsing this forum: No registered users and 23 guests
