It is currently Mon Nov 17, 2025 10:24 pm
PostPosted: Mon Mar 04, 2024 6:39 am
The pen points to it in the picture.
I think all slant 6 122T bell housings have this hole - the old, venerable 3-speed housing, the big heavy cast iron a833 ('64-'66) bell housing, and the aluminum '76-'87 a833/OD - I am pretty sure they all have that hole.
What is supposed to bolt there? I have never seen anything thread into that hole.
Another Slant 6 mystery wrapped in an enigma? :?:
PostPosted: Fri Mar 08, 2024 7:28 am
Apparently nobody else has either Greg.
PostPosted: Fri Mar 08, 2024 9:53 am
Well…h'mm.
Long ago, Bob Stepp and Doug Dutra had a running quip in the pages of the Slant-6 News that the mysterious throttle body hole was a secret passageway to China. We see from the link that's not so, but that just means the mysterious hole in the carburetor isn't the secret passageway to China. It doesn't mean this what you're showing us on the bellhousing isn't. How much string can you push into it? Give it a try and see; if you can lose 7,915.5 miles of string in that hole, then pretty good odds…!
PostPosted: Fri Mar 08, 2024 11:05 am
Wormhole. The string will come out the carburetor hole...
--> The Diesel Corvette <--
PostPosted: Fri Mar 08, 2024 11:41 am
Where's Willem Weertman's little black book of secret throttle passages and bellhousing holes when you need it??
Nah nevermind,
I figured it out!
It is for the varying torque input encoder and translator balance pole that sends quark inputs to the turbo encubalator.
Sorry to have bothered you with such trivial questions. It seems to be an obfuscation hole.
:mrgreen:
PostPosted: Fri Mar 08, 2024 11:59 am
Confirm nor deny the existence of such a book.
SHHHHHH! Pipe down, willya? It's a secret!
You watch your filthy mouth, mister! :mrgreen:
:mrgreen:[/quote]
PostPosted: Fri Mar 08, 2024 12:00 pm
…then you grab hold of both ends and pull back and forth to remove all traces of plaque before brushing.
PostPosted: Fri Mar 08, 2024 5:58 pm
I am guessing something during manufacturing, or a part used on a taxi, or industrial application.
I don't see them manufacturing the part with an unused hole.
PostPosted: Sat Mar 09, 2024 6:29 pm
Extra attachment screw for a non-A-body bellcrank pivot bracket??? No tin/shield that may use it?? Pic of the backside of the bell there?? What thread size?? Damnit, now I'm going to have to look at Mine in the AM.... :lol:
PostPosted: Sun Mar 10, 2024 6:34 am
Car Model: '23 T-bucket
Purely speculation, but was that same bell housing used in Aussie cars? Might it be for something that is down-under-only related?
Roger
PostPosted: Sun Mar 10, 2024 9:48 am
Roger
Do turbo encabulators spin backwerds in South Africa, Argentina, and Australia and other southern hemisphere places?
Maybe the owners of the DeSoto A Bodies know the answer to that one. :D
PostPosted: Sun Mar 10, 2024 1:07 pm
No.
PostPosted: Sun Mar 10, 2024 1:53 pm
No Turbo Encabulation on the '64 drop-top GT 3-on-the-tree, but that threaded hole is apparently used primarily by Mud Daubers, :roll: . I vote for transfer/assembly fixture.
PostPosted: Sun Mar 10, 2024 4:56 pm
No.
Makes sense if they were delivered as kdk cars and then assembled on the island. A different bellhousing would have been required due to the clutch linkage and "z bar"/ torque shaft, clutch pedal being on the right instead of the left.
