It is currently Mon Nov 17, 2025 8:43 pm
Post new topic  Reply to topic  [ 52 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Apr 05, 2024 2:11 pm
Car Model: 1983 Dodge D150
Got the cam back from OC. Here is the specs.
PostPosted: Fri Apr 05, 2024 5:46 pm
Paint on the block looks good. Hope it holds up.
I had a big idea to paint my /6 with a compressor and a paint gun. That backfired. I like the other por 15 products so I tried their engine paint. Never again. Though I admit it was an old batch.
My engine too came back from the machine shop painted (primered?) gray. I went to spray it, I used a small "detail" gun since I was just doing 1 engine.... It came out "watery" and after several coats it looked more "anodized" than painted. I ended up doing exactly what I was trying to avoid once the gun sprayed paint tacked up and that was to spray bomb it with duplicolor engine paint.
PostPosted: Sat Apr 20, 2024 4:25 pm
Cam is in and bolted up the oil pump. It's tight. Tough to spin the cam with the oil pump in place. Is this normal? New old stock mopar oil pump. Finally starting to put this together.
ETA Picture of cam before installing.
PostPosted: Sat Apr 20, 2024 4:42 pm
shouldnt be.
did you spin the cam by itself before you bolted up the pump? Could be "tight" cam bearing or a burr.
I mean yeah, youll feel some drag with just the cam and oil pump but it shouldn't be "tight"
PostPosted: Sat Apr 20, 2024 5:27 pm
Agreed, many times the cam bearings are tight.
Some sanding and fitting is normal.
Of course it will work its self in after the break in period.
PostPosted: Sat Apr 20, 2024 7:24 pm
Cam spun freely. With the oil pump in it just moves forward and backward. I can get the oil pump to spin but it takes effort to hold the cam in place. Went ahead and put the crank in. Had trouble getting the 3 oil rings to slip into the groves. Number 1 piston took a bit of fiddling then they popped in. 2nd piston the bottom ring and wavy ring would not fit in the groove. Guess I wasn't holding my stuff right. Will try again tomorrow. Tired and going to bed.
PostPosted: Mon Apr 22, 2024 3:41 pm
I loosened the oil pump bolts and the cam spins freely. Tightened bottom 2, with the oil engine upside down so the top 2, and still spins freely. Held the pump away from the cam. Started to tighten the bolts that would push the gear drive closer to the cam and it gets tight. Thinking I should swap my old gear on. Searched and found a bunch of failures but nothing saying tight on install.
PostPosted: Mon Apr 22, 2024 6:06 pm
The back of the cam timing gear basically keeps the cam from going too far back. That may be some of the issues of "hard turning" is that you weren't lined up exactly where it wants to go
PostPosted: Mon Apr 22, 2024 6:55 pm
Trying to keep the gears centered on each other when turning. It is not the original cam. OCG sold me a blank rather than weld up the old fuel pump lobe.
Does the oil pump push forward and the cam lobes push backwards? That seems to be what I remember. Would not like the cam trying to grind through the timing chain cover.
PostPosted: Tue Apr 23, 2024 4:06 pm
Oregon cams welded my fuel pump eccentric. Cost $40 for that and regrind to stock usable. Over and above the price of the regrind. I have damneer as much in shipping back n forth as I do in the regrind+ fuel pump lobe repair.
PostPosted: Tue Apr 23, 2024 5:43 pm
A reweld is $50 now and they sold me a new blank for $30.
I put the old pump in with the old original gear and it spins free. Has a little play in the 2 gears. I will put the old gear on the new pump and try that. Hope I didn't ruin the gasket by tightening the old pump to the block.
Put 4 more pistons in and stopped for the night.
There are 4 marks on one side of cap nuts. The other side is smooth. Which side goes toward the rod? Some are shiny on one side and others are shiny on the other.
Added a dog picture at the bottom. She is a good girl helping me in the garage.
PostPosted: Fri Apr 26, 2024 3:28 pm
Update. Found some problems.
1st I marked the connecting rod caps before removing. #1 cap was on backwards. Probably not a big deal.
B.) The machine shop installed the pistons backwards. Notch to the front and oil spray holes are on the wrong side. Not the cam side. Of course they are all installed with rings before I noticed.
Back to the machine shop or spin them around.
PostPosted: Wed May 01, 2024 11:58 am
Deleted.
PostPosted: Wed May 01, 2024 2:21 pm
Don't want to bring up the uncle Tony battle about running pistons backwards again but I'm sure it's coming
PostPosted: Wed May 01, 2024 4:19 pm
Has anyone here ran stock pistons backwards? How noisey are they?
Called the shop and he mentioned he hopes they don't break one getting the rod pin out. I'm tempted to spin them 180 and go with it. The extra couple of hp would not hurt. Would rather build a long lasting engine though.
Back in the '70's I ran the pistons backwards in my 170 valiant. Didn't notice any extra noise, but was running loud exhaust. Don't know if it did any good, but at the time it was the "hot trick".
Users browsing this forum: No registered users and 17 guests
