It is currently Mon Nov 17, 2025 2:26 am
Post new topic  Reply to topic  [ 109 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Fri May 10, 2024 11:22 am
SL6 Racer
FYI
I was at Oregon Cam this morning picking up some race oil from him and I asked Ken what was one of his bigger cam profiles for the .904 mopar lifter.
Grind #1543
intake 289* duration at .050" .647" with 1.5 .690" with 1.6 rocker arm ratio .026 valve lash
exhaust 289* duration at .050" .650" with 1.5 .693" with 1.6 rocker arm ratio .026 valve lash
lobe separation on this one is 108
Big cam with lots of lift.
PostPosted: Fri May 10, 2024 12:50 pm
FYI
Grind #1543
Is that one in a roller flavor or flat tappet variety?
Thanks Dave & Ken!
PostPosted: Sun May 12, 2024 12:49 am
Gotta be flat tappet, but Dave can verify.
PostPosted: Sun May 12, 2024 5:02 am
Definitely not a lawn mower cam. :mrgreen:
PostPosted: Sun May 12, 2024 7:47 am
What is this fascination with lawn mower cams?
PostPosted: Sun May 12, 2024 8:02 am
People have grass to cut!
PostPosted: Sun May 12, 2024 8:53 am
SL6 Racer
It was a flat tappet for the super x series lawn mower. Only sold in the Pacific Norhtwest.
PostPosted: Sun May 12, 2024 10:39 am
:lol: Here in Seattle East, it grows 4"+/day, & rarely has a chance to dry out. We need a huge mid-range torque curve, :lol: :lol: ...
PostPosted: Sun May 12, 2024 12:31 pm
SL6 Racer
Well, anyone that know me, knows that I do everything to a slant six that you are not suppose do. With that being said my lawn mower is no different.
I will be removing the flat tappet camshaft from the mower this winter and will be upgrading to a more aggressive roller camshaft.
OC grind number #1542 296* intake 302* exhaust with .824 valve lift.
This should provide more midrange power even suitable for the Seattle area.
PostPosted: Sun May 12, 2024 1:20 pm
But with our Slant 6 head there is only very small gains in any flow after .550 lift unless someone has found a new mystery head. So wouldn't be much easier on equipment and make just as much power to have the same duration and much lower lift than .697? Just wonderin! :D
PostPosted: Sun May 12, 2024 5:52 pm
Try to keep up, anything with .550" or less lift belongs in a lawnmower. :mrgreen:
PostPosted: Sun May 12, 2024 6:12 pm
This is a guess, and ONLY a guess, but the longer you can keep the valve at or above optimum flow, the more power you can theoretically make.
PostPosted: Sun May 12, 2024 6:36 pm
SL6 Racer
Sorry...this was just a little Kelso WA humor. I'm not putting a .800 " lift camshaft in my single cylinder, flat head, Brigs & Stratton lawn mower engine.
just some FYI how big OC can make a roller camshaft.
PostPosted: Sun May 12, 2024 7:27 pm
I think if you tried to do so, you would bend the valve on the head anyway! :D :D
PostPosted: Mon May 13, 2024 6:17 am
How big they can make Roller Cam or Flat Tappet?
I am trying to keep up....
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
