It is currently Wed Nov 19, 2025 3:38 am
PostPosted: Wed Aug 11, 2004 10:51 pm
Switching from stock .830 to .870 bars.
How low can I go with these?
Are those moog problem-solver bushings used solely to compensate for geometry changes when you lower the front end?
If so, can I go low enough with .870s to require these special bushings?
note: it is a 63 2-dr hardtop =~ 2570 pounds
PostPosted: Thu Aug 12, 2004 7:46 am
With any T-bars, you can only go as low as the bump stops will allow (unless you modify them). You need at least 3/4" between the LCA bumpstop and the frame contact point, or you will bottom out readily and your suspension will not be useful.
The camber/caster does get a bit worse when you lower things, so the problem solver bushings (with one reversed for best caster increase) are a good idea in any case.
PostPosted: Wed Aug 18, 2004 4:46 pm
This might help. http://www.ingallseng.com/performance/camberchange.htm
