It is currently Mon Nov 17, 2025 2:35 am
 Post subject: Windshield Interchange?
PostPosted: Sat Jul 13, 2024 9:52 am
Can someone with access to Factory parts numbers/ books look something up?
Is the '60-'62 A body valiant / lancer Windshield Glass the same as the 1960-74 LCF series Trucks ( Dodge / Fargo 500-1000 Series)
I know it's a long shot on the windshield, but they debuted the same model year, the exterior door handles are the
same, and Ma MoPar did use part #'s across multiple lines.
I was looking at one today and it seemed to be a similar shape.
Thank you Sages!
PostPosted: Sat Jul 13, 2024 1:40 pm
I give up trying to post the answer to this question, with pics and everything. Perhaps once the board is no longer broken.
PostPosted: Sat Jul 13, 2024 2:28 pm
Thank you l, It's appreciated when the board is back to normal.
PostPosted: Fri Jul 26, 2024 1:59 pm
Okeh, now we're back to firing on all six (thanks, @Chuck !):
No, they're not even a little bit the same. Compare them side-by-each; lookit the upper corners. Lookit the lower corners. Lookit the A-pillar angle. Lookit the part of the glass outboard of an imaginary line from the upper to lower start of the wraparound; on the truck there's a triangle of glass, on the Valiant-Lancer car there's a narrow strip. Lookit the top curvature; lookit the bottom curvature.
PostPosted: Sat Jul 27, 2024 6:31 am
Of course it fits. A nice rubber hammer , some Gorilla tape and some silicone. Good as gold. :D :D And I didn't even need pictures. :D
PostPosted: Sun Jul 28, 2024 6:09 am
Great, Thanks
I was looking at a big truck from down low and the bottom corners made me think about it.
Well good to know that they will not swap unless Rick's method is used.
