It is currently Mon Nov 17, 2025 2:51 pm
Post new topic  Reply to topic  [ 905 posts ]  Go to page Previous 153 54 55 56 5761 Next
PostPosted: Tue Aug 27, 2024 4:43 am
Online
Thanks Will.
If all goes well, I’m gonna look to re-set your 11.44 and 119 MPH records in the 1/4.
It starts to feel a little light at 97 MPH though.
I’ll add the second battery… I didn’t ever think I would have a race car that actually needed a rear spoiler, but maybe it would help…
PostPosted: Wed Aug 28, 2024 11:49 am
Yep, good to get some kind of spoiler on there, especially for 1/4 mile. Let's talk on Saturday at CC... Very exciting!
PostPosted: Wed Aug 28, 2024 4:58 pm
Online
I changed the oil, added the second battery and re-weighed it.
With a simulated 200 lbs in the driver seat (floor jack, battery, 5 gallon fuel jug, etc.) it comes in at 2,332 lbs.
PostPosted: Wed Aug 28, 2024 5:02 pm
With that squared off back window you may need a wing. Mike put one on the Valiant because it started getting light when he was spraying it.
PostPosted: Wed Aug 28, 2024 5:10 pm
Online
Yeah,… It starts to feel a little light at the top of the 1/8th…
Not sure I want to try for 1/4 mile until I feel it out a bit more.
I s’pose I could steal a spoiler off the Neon or MR2… :|
PostPosted: Wed Aug 28, 2024 5:52 pm
What tire pressure are you running?
PostPosted: Wed Aug 28, 2024 6:59 pm
Online
I believe Howard set them at 10 or 11…. I will verify. I have tubes, so I can drop the pressure more.
PostPosted: Wed Aug 28, 2024 8:06 pm
You using radial or bias slicks?
PostPosted: Thu Aug 29, 2024 3:26 am
Less pressure means more squirrely at the big end maybe.
PostPosted: Thu Aug 29, 2024 4:52 am
Yes, too little pressure will make the car "squirm", especially when you get off the throttle at speed.
PostPosted: Thu Aug 29, 2024 6:13 am
Online
The car didn’t feel really squirmy up top or move around when I let off. It just felt “light”… :?
Kinda like you feel when you’re driving in the rain and just start to hydroplane…. That “Ooohhh… Here we go!” Kinda thing.
The last pass when it got loose and I had to lift was most likely the dew on the track. There weren’t many cars and it was just test & tune, so no track prep to speak of.
PostPosted: Thu Aug 29, 2024 6:14 am
Online
The tires are M/T radials I believe. I’ll verify.
PostPosted: Thu Aug 29, 2024 6:47 am
Online
I've got an 8000 if you're brave.
Stan might want that one! :D :D Sorry Stan I lost my mind there for a second. :D
Right now I have my high side (over rev) set at 7200 I think. Shifting at 6700. :mrgreen:
My highest chip is 7000. The shift light is set at 5800, but it’s still pulling beyond that. Soooo,… I tried to ignore the bright yellow light and shift by feel… I hit the 7000 rev limiter a couple times.
I would adjust the shift light, but the button fell out somewhere… :roll:
PostPosted: Thu Aug 29, 2024 7:57 am
Radials will need more air than a bias.
The pics in your garage of the burnout showed low air in the pattern.
BUT, that does not take away from the fact that in the 1/4 you will probably need a wing on the back to keep it straight. That's a fast little hot rod.
PostPosted: Thu Aug 29, 2024 9:39 am
If you all get to run, Hopefully someone can get some video of everyone.
