It is currently Wed Nov 19, 2025 8:45 pm
PostPosted: Sat Aug 21, 2004 10:17 pm
I went to the yard and jerked an A arm off a like vehicle. Might have been a '73 or '72. Not sure. Mine is a '74 Scamp. Brought it home and low and behold the ball joint is smaller. What's the deal? What year A bodies have compatable A arms? The A arm looks identicle but the threaded hole is smaller on the JY vehicle. Can I get a smaller ball joint for the new arm and be ok? Or is there other geometry differences that would be overriding.?
One other problem I should mention. Per my other posts this is related to the welded upper ball joint issue. The other UCA was not welded and I removed the old Ball Joint just fine. When I tried to put the new ball joint in it just spins without seating. I can't get a decent torque on it. WTF. It seems like I need both UCA's. Now I can see why the other one was welded. Aaargh!!!!!!!!!!! Is this a common issue??
Sweet Emotion
PostPosted: Sun Aug 22, 2004 8:17 am
that is the difference between a 9" drum car and a 10" drum/disk brake car
PostPosted: Sun Aug 22, 2004 10:36 am
No, this is not a common issue. It sounds like some ham fisted mechanic was having way to much fun. You can use the UCA from any of the following vehicles: '66-'72 B-body, '70-'74 E-body and '73-76 A-body. The A-body must have had disk brakes.
 Post subject: 73 on BJs
PostPosted: Sun Aug 22, 2004 10:51 am
All 73+ a-bodies came with the larger b-body balljoint, even my 73 Scamp with drum brakes and drum brake spindle up front uses the larger balljoint.
PostPosted: Sun Aug 22, 2004 2:43 pm
It sounds like the control arm you grabbed was from a '72 after all - '73 was the year they redesigned it for the larger ball joint.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
Users browsing this forum: Ahrefs [Bot] and 5 guests
