It is currently Mon Nov 17, 2025 6:48 am
 Post subject: Mystery Comp Cams ID?
PostPosted: Sat Jan 11, 2025 4:55 pm
Online
Does anyone have old slant 6 comp cams information or listings?
Looking for more information on a cam that has 0.426" Lift on the intake Valve.
I know that is not much to go on.
PostPosted: Sun Jan 12, 2025 5:25 am
Car Model: 1966 Dodge Dart
Maybe you have a 252H? Intake lift is off by 1/1000".
https://www.compcams.com/high-energy-20 ... inder.html
Matt Cramer
PostPosted: Sun Jan 12, 2025 7:03 am
Online
Thanks, Matt.
I was told that it was a solid Lifter cam, But that information and link you sent is sure real close.
This was a mystery cam installed in an engine with a bunch of other slanted parts in one of those "buy this, and get everything with it" bulk buys!
I am sure we don't want to run a Hydraulic Cam with Solid lifters, pushrods and valve gear. So I may have more investigation to do.
I should have measured the Duration at 0.050" on the Intake and Exhaust and the exhaust lift, but I failed to gather that date with my wheel and micrometer.
That would have given me more information to be precise on all of this.
PostPosted: Sun Jan 12, 2025 12:03 pm
Probably a 252S. Seems like I had one on the shelf at the shop.
PostPosted: Sun Jan 12, 2025 2:40 pm
Online
Hi Dennis, are there any specification sheets available for that cam?
Is it older and not in production any longer?
PostPosted: Tue Jan 14, 2025 3:42 pm
I have that cam card.
I will send you a text.
Will
PostPosted: Tue Jan 14, 2025 4:16 pm
Online
Will
Got it. Thanks Will.
Users browsing this forum: No registered users and 17 guests
