It is currently Mon Nov 17, 2025 3:58 am
Post new topic  Reply to topic  [ 318 posts ]  Go to page Previous 118 19 20 21 22 Next
 Post subject: Re: Covalt - 85 D100
PostPosted: Sat Jan 18, 2025 8:47 am
When I had the "brain" issue and was trying to find out why I didn't have oil pressure, I actually swapped out the oil pump for one i had on the shelf. It was an early, aluminum, narrow rotor pump and had about 50# at WOT and 20-25# hot at idle. But I had the original pump that was mated to the cam in the truck; so yesterday I unbolted the RH motor mount and jacked the engine up a smidge. I removed the aluminum pump and installed the newer wider rotor pump that went with the camshaft. Fired everything up and took it for a ride. Allowed temp to get up to about 200 degrees so I know everything was hot. Checked my pressures and had about 52# at WOT. But my idle pressure was up at about 35#. I am guessing the wider rotor pushes a little more volume at idle than the aluminum pump did. Now to find that pesky rattle I hear every once in a while! :D :D
PostPosted: Sat Jan 18, 2025 11:17 am
That is as it should be. Look at it this way. If the rotor is 10 % wider, then at any given rpm the pump will pump 10% more oil. So with the restriction of the oil system being the same, the pressure will increase at any given rpm. This will hold true until the pressure reaches the pump bypass valve setting, at which point the valve will open and bypass the excess oil volume to maintain the pressure at that number.
This is why changing the bypass spring will have no effect on the low rpm oil pressure, with a given pump. The pump does have enough volume and just cannot supply enough oil to the engine. It is also why in most cases a slant does not need a "high volume" oil pump.
PostPosted: Sun Jan 19, 2025 8:22 am
Charlie explained it very nicely!
PostPosted: Sat Feb 01, 2025 11:18 am
I finally pulled the engine apart that we removed from the truck after the Knoxville race. I think I found the problem. :D :D
Pretty sure that is why it had so much blow by. :D It also had a couple other top rings broken but still in place. This was a "quick" re-ring on an old engine I picked up for cheap. I cut the cylinder ridge and then did a quick hone and installed new rings and bearings.. I imagine the rings broke first then the piston went down hill from there. The engine had run 5 or 6 racing seasons in my Valiant, then was placed in the truck for the last 2 or 3 years. It made trips to London, Knoxville. Wilkesboro...etc, so it probably had 8-10000 road miles on it before this happened.
I already have a set of reconditioned rods with .030 over pistons on them. So I will probably just get the block cooked / cleaned and then bore it .030 over. Crank looks pretty good but will need a polish at least.
PostPosted: Sat Feb 01, 2025 2:34 pm
nice to find out what happened.
Looks like some of Charrile's Nitrous Passes pistons.
Maybe Ryan put the Hose sprayer on there when you were not looking?
PostPosted: Sat Feb 01, 2025 4:40 pm
:lol: :lol: :lol: :lol: :lol:
PostPosted: Sat Feb 01, 2025 7:01 pm
I looked closely and could not find any hidden nitrous bottles! :D
PostPosted: Sun Feb 02, 2025 4:38 am
That's good but you were busy that weekend not getting red lights, playing with GM LS Spark plugs and such!.. I bet he threw it in the creek before you came by, then said, "it's running badly."
:D :D :D
PostPosted: Sun Feb 02, 2025 1:15 pm
At least it's not too horrible. :mrgreen:
PostPosted: Sun Feb 02, 2025 4:39 pm
So a 3/4" wide ring land should be Ok? :D Just run 20W 50 oil.
PostPosted: Sun Feb 02, 2025 5:00 pm
Straight 50 with 2 cans of STP added. :P
PostPosted: Sun Feb 02, 2025 7:13 pm
As opposed to rods kicked out the side......
PostPosted: Sun Feb 02, 2025 8:32 pm
Yeah! For sure. Really surprised it ran home 500 miles as well as it did. :D
PostPosted: Mon Feb 03, 2025 6:47 am
Thanks for the detailed report, Rick. Best wishes getting it back together in better-than-ever running order.
PostPosted: Fri Oct 31, 2025 8:13 am
Finally began the reassembly of the 5 cylinder engine that gave up the ghost at Knoxville last fall. Since we haven't had any races this year I only drove the truck about 1400 miles since I installed my back up motor in December.
I had disassemble the "broke" engine and had the crank polished. Luckily it did not need a regrind and all the bearing sizes are still std.size. I sent a good used cam to Oregon and had it reground to a newer grind that is not on our old cam list in the FAQ. It is cam #2106 and I used the Exhaust pattern on both Intake and exhaust. .444 lift, 214 duration at .050 and 110 lobe separation. Intake centerline is 108 and when I installed the cam without any offset bushing it came in at 105 degrees. So I called it good. Interesting that when I first installed it just lining up the dots it was way off! I had to move the chain on the cam 1 tooth to get it where I left it. This has happened sooo many times to me on rebuilds that I would never install a cam without degreeing it.
Next it gets the cylinder head and pan installed and then it should be ready to reinstall in the truck. I likely will just install a 2 barrel intake and stock exhaust manifold. With this mild build it really is a waste to install a rare Weiand manifold, 4 barrel and hooker header just in case I decide to sell it. More to come! :D :D
Users browsing this forum: No registered users and 29 guests
