It is currently Mon Nov 17, 2025 2:11 am
PostPosted: Sat Apr 12, 2025 1:44 pm
I've read that one loosens the tie rod ends and then turns the adjusters (equally?) to move the steering wheel to straight. I am learning more and more how to do things to my 65 Valiant and this is one I wouldn't want to misalign now that my car drives true. Thoughts?
PostPosted: Sat Apr 12, 2025 3:10 pm
It is easy to do. (2) 1/2" wrenches (box end perferred) and then you need to set your toe again after resetting the wheel straight.
A tie rod tool is useful as well.
Align shops can do this fast with turn plates , lasers and a drive on rack that is 12"-24" off the floor.
You will be likely crawling around on the shop floor a lot back and forth from side to side many times up to 20-30x to adjust toe and steering wheel center. Then some test drives to see of you got it right.
A good set of toe plates and 2 tape measures are what I use.
I suppose you could also use strings and jack stands around the car.. I have never used that method however.
PostPosted: Sat Apr 12, 2025 5:55 pm
To reduce Greg's excellent description to its essential concept:
In theory, it's extremely easy: Rotate sleeves equally and you will move the position of the steering wheel relative to the steering linkage. Do it perfectly and you will not affect your toe-in.
In practice... How's your frustration tolerance?
– Eric
PostPosted: Sat Apr 12, 2025 6:35 pm
Before you go to the trouble, make certain the steering wheel is installed correctly on the splines at the top of the steering shaft—yes, there's a master double-wide spline meant to index the wheel to the shaft, but it's not foolproof; I've seen that defeated many times.
I don't recall if there's a master spline on the steering gearbox input shaft, but it would stand to reason there would be; that would bear checking, too.
