It is currently Tue Nov 18, 2025 4:48 am
 Post subject: Turbo coolant lines
PostPosted: Fri Sep 12, 2025 3:16 pm
Car Model: D150
Still collecting parts to turbo my D150. I have questions about coolant hookups for my Toyota ct26. Some people use their heater hoses to tee off of. Can I use the top of my thermostat housing with an added port to supply coolant? And to add a port to my croosflow radiator to use for a return? Or am I looking at problems with this scenario?
 Post subject: Re: Turbo coolant lines
PostPosted: Sat Sep 20, 2025 1:18 pm
Car Model: 1966 Dodge Dart
You'll want the coolant supply to be upstream of the thermostat (possibly drilling and tapping the cylinder head). There's a significant pressure drop through the thermostat and tapping downstream of the thermostat will not get enough pressure to circulate the coolant.
Matt Cramer
PostPosted: Sat Sep 20, 2025 4:31 pm
Car Model: D150
Thank you mad scientist. How about the port where the temp sensor is?
PostPosted: Sat Sep 27, 2025 1:54 pm
Sure, it's functionally the same as the upper radiator hose port.
Matt Cramer
