It is currently Mon Nov 17, 2025 6:05 am
PostPosted: Wed Oct 15, 2025 5:31 pm
Working on a truck cab. '90 model, cab going on my 83.
Drip rail over windshield is holey. I figured lead would stick better and seal better, preventing/ drastically slowing down further rust better than anything else. Thoughts? How to tips?
I've fixed a few cracked copper radiator tanks by soldering over the years, (never replaced a tank by soldering before though) and I've sweated lots of copper plumbing pipe fittings over the years so I kinda understand the process somewhat.
I wish I knew an old school Gene Winfield type around here...
PostPosted: Thu Oct 16, 2025 6:08 am
Car Model: 78 aspen
i have only played with it. have not actually used it. but i will.
found this when i started...
https://m.roadkillcustoms.com/lead-lead ... -winfield/
good article, even better how to video
PostPosted: Thu Oct 16, 2025 9:39 am
When I re-did my truck I removed the visor mounts and sprayed a rust killing agent up into that area. Many of these trucks rust in that area. I also thought of laying a couple of layers of fiberglass down over those areas.
PostPosted: Thu Oct 16, 2025 1:11 pm
There are videos of it being done on youtube. When I put my valiant back together and fix its rust issue I have been very tempted to go the lead route. It is supposed to prevent future rust out way better than bondo. All the old timer customs of the 50s,60s,70's were made with lead. It is what coined the term "lead sled" from my understanding of old hotrodding. Chop tops and the like were leaded.
Just do your research. Modern "lead" solder has a different melting point than the traditional lead from long ago. You can likely buy pure lead still but it is going to be hard to acquire depending on your local laws/regulations. When I last looked eastwood still stocked normal lead in addition to modern lead solder and all the tools required. Make sure to wear your protective gear you won't like the fumes.
The solder used for copper pipes is not the same. I am not sure they will even sell lead solder for plumbing at this point due to the health issues.
PostPosted: Thu Oct 16, 2025 1:32 pm
Lead won't work for that. The only repair is to cut the rust out and weld new metal in. After that, it would work as smoothing agent just like the plastic fillers. But would be more difficult to work with and require different tools and methodology's.
PostPosted: Fri Oct 17, 2025 11:07 am
I tried to get pix. The underside pix won't come out t like I had hoped. Pix of the top side came out blurry at best. The outer (top) layer doesn't look terrible from the underside, , most of the damage is underneath. With the top layer there to "collect" and hold lead or whatever I can fill it with. I don't see being able to get in there from underneath and weld anything in. I can probably use a copper bar as a backup and weld in the few spots that are completely thru. I think if I lay the cab on it's back I can get some lead to stick in there on the underside while using the underside of the top layer (roof skin) as a backer much like it would be if just filling in pitted metal
PostPosted: Sun Oct 19, 2025 2:44 pm
I'm gonna try for better pix here in a bit.
I'm not liking this idea but I went up to the Eastwood store yesterday expecting to buy a couple of lead bars and all the associated stuff (flux, tallow, etc) and I talked to an employee there and instead of lead he suggested this aluminum powder fortified "Bondo" (their brand) or a name brand called (I think it was). "all metal" I remember using a similar product years ago and it seems that stuff was quite brittle.
This stuff is supposed to be "water proof" but I have my doubts.
PostPosted: Sun Oct 19, 2025 2:49 pm
Yeah I get that solder for copper pipes isn't the same as what would be used for body lead. But I'm thinking the process is similar. I was at Eastwood yesterday and what they have is a 30/70 tin/lead mix, as I understand it original body lead was 40/60.
