It is currently Wed Nov 19, 2025 3:38 am
PostPosted: Sat Aug 28, 2004 3:06 pm
I'm installing the LCA bushings and strut rod bushings on the K-frame right now and I'm wondering if I should apply some lithium grease on the bushings or some other kind of lube.. The new bushings are polyurethane. I don't want to use something that will deteriorate them.
Thanks.
Sweet Emotion
PostPosted: Sat Aug 28, 2004 3:48 pm
Not only should you, but you must with polyurethane... (lower control arm) The problem will be when that grease dries out and they start "popping" and squeaking...
D/W
If it ain't broke, fix it!
PostPosted: Sun Aug 29, 2004 8:25 am
I looked in the box I had everything in and I found a small tube of "special formula" grease that came with it. Thanks.
Sweet Emotion
