It is currently Tue Nov 18, 2025 12:34 am
 Post subject: Re: Angle Milled Head
PostPosted: Fri Nov 14, 2025 5:16 am
Good to know, Mark. I had a phone call with Stan yesterday and laid out my thoughts and possible advantages... Glad you guys got together in Tulsa.
Best,
PostPosted: Mon Nov 17, 2025 7:14 am
We did.
Care to spill any speed secrets?
Did you think it was worth the effort?
Is it on the lump of cast iron in my garage?
PostPosted: Mon Nov 17, 2025 8:41 am
Enquiring minds want to know! :D :D
PostPosted: Mon Nov 17, 2025 11:39 am
You can tell if a head has been angle milled by measuring with a caliper from deck surface to valve cover machined mounting surface, for the manifold side and then the spark plug side. The measurements will be within a few thou if it has been flat milled, but different if angle milled.
