It is currently Mon Nov 17, 2025 10:25 pm
PostPosted: Wed Jun 20, 2001 12:10 pm
I have a '66 Valiant wagon and would like to add disc brakes and custom wheels. The stock wheels have 5 on 4" bolt circles. I would like add 14x7 wheels with 5 on 4.5" bolt circles. Are there axles that I can swap out from another car? If not, how about an entire rear end? What car(s) can I get the discs and axles (or rear end) from and what parts do I need?
Gary
theluketribe@hotmail.com
PostPosted: Wed Jun 20, 2001 9:58 pm
: I have a '66 Valiant wagon and would like to
: add disc brakes and custom wheels. The stock
: wheels have 5 on 4" bolt circles. I
: would like add 14x7 wheels with 5 on
: 4.5" bolt circles. Are there axles that
: I can swap out from another car? If not, how
: about an entire rear end? What car(s) can I
: get the discs and axles (or rear end) from
: and what parts do I need?
Any big bolt pattern A-body rear end will do the trick. These started in 1973, mostly on V8 cars.
Moser also sells "conversion axles" and can also redrill bolt patterns if needed.
PostPosted: Wed Jun 20, 2001 10:08 pm
Try this site for information...
<A HREF="http://www.geocities.com/motorcity/shop ... sk.html</A>
At the bottom of each page they have links for other pages like rearends and such...
Good luck
: Any big bolt pattern A-body rear end will do
: the trick. These stared in 1973, mostly on
: V8 cars.
: Moser also sells "conversion axles"
: and can also redrill bolt patterns if
: needed.
: DD
: DD
bduffy@onemain.com
