It is currently Wed Nov 19, 2025 10:18 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Brake Booster
PostPosted: Fri Jul 20, 2001 11:26 am
When converting to power brakes, besides needing
the booster, MC, and P valve, do you also need
lever assembly and push rod that attach to back of bosster? If so, can it be purchased new or is it a swap meet/JYard item?
Thanks
 Post subject: Re: Brake Booster
PostPosted: Mon Jul 23, 2001 12:35 am
: When converting to power brakes, besides
: needing
: the booster, MC, and P valve, do you also need
: lever assembly and push rod that attach to back
: of bosster? If so, can it be purchased new
: or is it a swap meet/JYard item?
: Thanks
you need everything but the pedal/lever assembly. Jyard is best bet. fits right in your tool box and looks like a driver/punch (not that I ever did that/recomend it) Most yards won't even charge you for it.
richard-c@e-d-a.com
 Post subject: Re: Thanks! *NM*
PostPosted: Mon Jul 23, 2001 5:16 am
