Only One Master Cylinder Reservoir?
https://mail.slantsix.org/forum/viewtopic.php?t=4436
Author:  Frank G [ Sun Nov 10, 2002 11:01 pm ]
Post subject:  Only One Master Cylinder Reservoir?
I am restoring my car piece by piece and I was wondering if I could install and bleed the front brakes without having to have the rears hooked up, you know, just leave the rear reservoir empty. Would I just plug the unused M/C outlet? Thanks.
Francisco
Author:  Doc [ Mon Nov 11, 2002 1:41 pm ]
Post subject:  Bench Bleed the Master Cylinder
It is possible to bench bleed the master cylinder, then plug the rear port and bleed the front.
If your car has a brake system emergancy switch / light I would not advise doing this because it will trip the switch. ( system pressure imbalance) These switches are hard to get recentered once they are activated / moved.
Look for a electrical wire going to the metering block. What year is the car?
